Rack and pinion
Discussion in 'Technical' started by DC12VOLT, Feb 3, 2010.
  1. DC12VOLT
    DC12VOLT Fuel Injected
    Everett, WA
    Cream 1971 Maverick
    I really want a rack and pinion setup (my dad says that's what I should invest in really) for my '71. I've seen a few Maverick-specific setups that were like $2,500 or something, and I really can't afford that. But there are TONS of rack and pinion Mustang II-style steering for Mustangs for way cheaper, and I was wondering how difficult it would be to adapt a Mustang one to my Mav, as well as what year of Mustang would be the easiest to adapt? I know both cars are based on the Falcon, so it shouldn't be too difficult, right?
    Also: How hard would it be to steer the car if I took out the power steering? I know it's like turning the wheels while the car is off, but with rack and pinion and at speed, would it be very difficult to drive?
  2. rthomas771
    Every cheaper kit I seen only gives you half the parts to complete the job. After buying the rest of the parts you have spent $2500. Rod & Custom is the best deal out there...everything is in the box. Other kits you will have to cut your car to fit their kit, with Rod & Custom the kit fits your car. Mustangs and Falcons are wider than a Maverick.
  3. eburciaga
    eburciaga Member
    Orange County
    1974 Maverick 4 Door
    no its real easy im 17 but i would prefer the power steering
  4. DC12VOLT
    Everett, WA
    Cream 1971 Maverick
    Did you have a manual steering box? They have an easier ratio in them.
    rthomas771: Can I get a link to that kit? I can't seem to find it.
  5. rthomas771
  6. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    rrs sells a kit that bolts right in, no fabrication needed
  7. DC12VOLT
    Everett, WA
    Cream 1971 Maverick
    The RRC kit is really expensive, that's why I'm talking about adapting a Mustang one...
    Thanks, that Rod & Custom kit is definitely the way to go!
  8. maverick maniac
    maverick maniac Banned
    owensboro ky
    you can use the mustang II stuff but you need the hole front end .It will weld in
    and is a lot cheaper way to go ,but again you need to use all the susp.parts off the
    mustang II
  9. Craig Selvey
    This is not a simple bolt in or weld in job. Not for an ameteur.
  10. DC12VOLT
    Everett, WA
    Cream 1971 Maverick
    I am aware of this, and my dad (the owner before the previous owner of the car, my brother) is going to help me, along with the Auto Shop teacher at my high school (lifts really help out).
  11. Matterick
    Matterick Matt Somerville
    Lake Stevens WA
    hey what highschool are you going to? do you take sno isle?
  12. DC12VOLT
    Everett, WA
    Cream 1971 Maverick
    I go to Cascade, and I'm taking Auto next year.
  13. Matterick
    Lake Stevens WA
    if you take sno isle that's where i go! (y)
  14. DC12VOLT
    Everett, WA
    Cream 1971 Maverick
    My friend's taking a CNC lathing class there I think.
  15. bmcdaniel
    York. PA
    '70 Maverick Grabber
    Of the other cars mentioned the Maverick has less distance between the frame rails so just bolting in a rack from another car limits the turning radius. That's why companies have developed the expensive aftermarket units.
