1970 Maverick brake lines using the 1968 Mustang Lines
Discussion in 'Technical' started by Dianne, Oct 28, 2013.
  1. Dianne
    Dianne Member
    Nampa, ID
    1970 Ford Maverick, 1973 Grabber, 1973 Pinto Wagon, 1978 Mustang King Cobra II, 2004 Mustang Convertible
    This is what was done, as was suggested by someone on here, I forget who now. But it works!
    He took a shock sleeve (the long tube) cut it in to 4 equal parts then with some valve cover bolts of a jag. I ground off its lower flange to run it thru the bracket. Then he drilled 2 small holes in the frame to hold the new brake line.
    Looks pretty darn good :D
  2. Dianne
    Dianne Member
    Nampa, ID
    Was the guy working on my car :)
  3. predfan2001
  4. Dianne
    Dianne Member
    Nampa, ID
    Yours looks good as well :) Either way they are both professional looking installs :D
  5. Krazy Comet
    Dismal Swamp
    That is a nice install...
    The disc brake hose bracket bolts directly to the frame rail on my '69 Fairlane, so unless same are too short that's how I'm mounting them on the Comet...
  6. Dianne
    Dianne Member
    Nampa, ID
    Thanks, he did a GREAT job on it!
