High torque mini starter upgrade.
Discussion in 'Technical' started by M.A.V., Jun 6, 2005.
  1. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    I just didthis swap on my car and I really like the results.
    The Starter is 1/2 the weight of our factory type units.
    you can put the TOP starter bolt on from under the car ,WITH headers,
    using your fingers! The starter is a factory Ford part and it WILL work with any Automatic weather its a 57 or 64 tooth flexplate.
    You can get them from the salvage yards or from your local parts house:
    Stock Replacement On:
    1992-1996 Ford Bronco 4.9L, 5.0L, 5.8L w/ AT
    1992-2002 Ford E Series 4.2L, 4.9L, 5.0L, 5.8L
    1992-1998 Ford F Series 4.2L, 4.9L, 5.0L, 5.8L
    1990-1991 Ford LTD Crown Victoria, Mercury Grand Marquis 5.0L
    1994-2004 Ford Mustang 3.8L
    1992-1995 Ford Mustang 5.0L
    1990-1997 Ford Thunderbird 3.8L, 5.0L
    1990-1992 Lincoln Mark VII 5.0L
    1990 Lincoln Town Car 5.0L
    1989-1997 Mercury Cougar 3.8L, 5.0L
    All you do is Move the Starter cable from the "switched"side of your relay over to the other side where the cable from the battery is connected.....Now run a 12 guage wire from the "switched side of your relay down to the starter and use a female "blade " connector to hook it to the relay on the new starter. Done! This is a High torque,compact ,permanent magnet Type starter that is superior in EVERY way to our old style "BIG" starter.
  2. 71gold
    thanks mike (y) ,
    i just sent you an e mail asking this question...what do they come stock on?...frank...:bouncy:
  3. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    And the cost of this , and the part # ?
  4. M.A.V.
    Macon,Georgia
  5. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    mini-starters are truly a great buy for our cars.
    Good stuff Mike.
  6. M.A.V.
    Macon,Georgia
    Here is what I paid for the Starter with a free install kit ( Wire with correct ends installed and 4 zip ties :) ) The Starter is Brand new,not rebuilt,and when I took it out of the box the quality looked good...only thing is
    On the box there was a sticker that says :
    Made in China :rolleyes:
    So far the starter is doing fine ...I really like it...We will see how it holds up.
    PriceTotal PFP-3205-N Ford SB: High Torque Mini Starter 1 $64.99
    PFP-79-2114Wiring Kit for Remote Solenoid 1 $0.00
    Sub Total: $64.99 Tax: $0.00
    Shipping: $10.26
    Grand Total: $75.25
  7. Mavaholic
    I would leave the battery cable on the switched side of the solenoid and just run a short jumper down on the starter. That way that starter cable is not hot all the time. I seen more arcs and sparks from the chevy guys changing starters because they forget or are too lazy to disconnect the battery first. Do it my way and you wont have to disconnect the battery.
  8. 71gold
    dennis,
    would you "draw" me a pic.so i can see what you are saying?:huh:
    thanks...frank...:bouncy:
  9. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I have mine wired the same way as Dennis! Works great
  10. 71gold
    got my starter today :bananaman :bananaman .
    thanks mike (y)
    my "alt./starter" man made me this jumper. this way everything hooks like stock...frank...:bouncy:
  11. maverick1970
    Missouri
    Frank looks like your set. Hardest part is getting the old starter out.
  12. 71gold
    the "boy" (chris), is on it right now (y) ...frank...:bouncy:
  13. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    I gotta get me one of those! I don't know how I got my starter in the first time, because I like to never got it in place a couple weeks ago when I replaced it! I am positive I put the headers on before I put the starter on last time because I remember putting all my extensions together to reach the top starter bolt from in front of the motor. :16suspect I priced the starter for a 95 Mustang at Advance and a new one was in the $160 range...
  14. hotrodmaverick
    hotrodmaverick Member
    Houston, TX
    1974 Maverick 2dr 302, 73 bumpers, 4 spd, disk brake 9-inch
    M.A.V., you said it would work with any automatic, will it work with a toploader?
  15. Mavaholic
    You got it Frank.
