need help on t-5 tranny swap!!!!!
Discussion in 'Technical' started by RoanokeMav, Apr 23, 2004.
  1. RoanokeMav
    RoanokeMav Member
    Roanoke, Va.
    1972 Maverick Grabber w/ 302 and c-4, w/ shift-kit, 3.00 gears.
    well i just bought a 302 out of a 91 f150. and 2 t-5 5 speeds... 1 has the 2nd synchronizer out and the other 5th gear torn out so i'll have to do some swapping but the one only has 7,500 miles on it...before some kid ripped it out. anyways i need info on making the swap from a c-4 automatic to the t-5 and a list of everything i need. i need info really bad so any pictures or just plain ol knowledge will work..... and maybe a tutorial...i couldnt find one on here because the stupid search engine has to have a 3 letter search...so t-5 doesnt come up.!!!!! thanks again.
  2. mercgt73
    mercgt73 Member
  3. wakywaco
    wakywaco Member
    waco
    1975 v8 maverick
    anyone used all this info so far to do a 5 spd swap?
  4. 71GTComet
    71GTComet Member
    Atlanta, GA
    1971 Comet GT(Sold) 1985 Ford SSP LTD
    im trying to do it this weekend i'll let you know how it goes for anyones whoes still interested
  5. 71GTComet
    71GTComet Member
    Atlanta, GA
    does anyone have any pics (im looking at you Blown76) of where to drill the holes in the clutch box?
  6. bmcdaniel
    To mount my T5 I had to cut out the dropped center section of the crossmember, move it 1 1/2" rearward and reweld it in order for the mechanical clutch linkage studs in the block and on the frame to align. The tranny mounting pad is farther back on a T5 than a C4/Toploader. Had to open up the top of the trans tunnel and add metal to clear the T5's shift rod tube and maintain correct trans/rear pinion angle.
