Choke help
Discussion in 'Technical' started by Shoestring, Dec 5, 2005.
  1. Shoestring
    Shoestring Member
    EL Reno, Oklahoma
    '74 Maverick
    Alright. When my Carb. was flooding out, the gass lines were dirty. I fixed that, and now my Choke sticks and whatnot. This is how it's been every since I got my Maverick (a few months back), fix one thing, two more problems appear. But that's what makes it so fun.
    Here's my question (I looked, and I just can't find it):
    I'm needing a Manual Choke. I went to Auto Zone, and they couldn't find it. All the guy could find was [font=arial,sans-serif][size=-1]"Choke Thermostat" and "Choke Pull Off". Which is the correct part? I'm still learning a lot from my dad about cars, so I didn't know what the heck to make of it :hmmm: I would ask my dad, but he's working today.
    All I want is a cable that goes to the Choke, that I can adjust from within the car.
    Thanks a lot for the help, guys.
    [/size][/font]
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I just installed a Manual Choke on my new carb today before I installed the carb in the car. Got the entire kit for $8 at Advance Auto in the Help section. I also tried Autozone's help section first but they didn't have any ...
  3. Shoestring
    Shoestring Member
    EL Reno, Oklahoma
    '74 Maverick
    I just got back from Bills Auto. They had one for $11.
    Any advice or tips you guys can share? I've never installed a Manual Choke before.
    Thanks a lot!
  4. dmhines
    Cumming, GA
    I just followed the directions .... Went on no problems. The lever they supply was a little too long to clear my air cleaner so I trimmed it down with a dremel.
    I mounted the pull handle to the left of the emergency brake handle ... yours will be a little tricker to mount since you have the dash with a glove box ... I installed a tray on my 74 so I just screwed it into the metal ... I drilled a 1/4 inch hole right through the firewall where the clutch rod would have gone on a stick shift car for the cable.
    Since I had a 6-cylinder the engine mount was a little tricky but I figured out how to use the Throttle cable bracket as a base for the mount. If you have a V8 there should be a bolt on the intake manifold to user for the engine side mount for the cable. Mine looks a little sloppy now but I;ll get it cleaned up ... I just wanted to make sure it worked ... :)
  5. Shoestring
    Shoestring Member
    EL Reno, Oklahoma
    '74 Maverick
    Hahaha - I wish I had a V-8! I got a 250 6-Cylinder, so i guess it's, as you stated, going to be tricky. I'll get it on, might take a while, but it will be on tonight.
    Thanks for them pics, Hines. Looks great!
