Instrument Cluster Tachometer Idea
Discussion in 'Technical' started by 75Maverick, Jan 27, 2005.
  1. 75Maverick
    75Maverick Ford Tuff! ~Ben
    Phoenix AZ
    1975 Maverick
    It would be cool to modify the left side of the instrument cluster to have a tachometer in it. There is sort've that empty space thats not used for anything. Here's an edited I made to see how it would look. Has anyone done this before?
  2. courier11sec
    courier11sec Member
    Tucson, AZ
    That might be pretty tough to do, but if you could pull it off it sure would be cool!
    (gears are turning in my head right now.) I have a plan!
    I won't steal your idea, but if you need help figuring out how to do this feel free to pm me.
  3. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I have not seen it done, but really like the idea and the look.
    Dan
  4. courier11sec
    courier11sec Member
    Tucson, AZ
    It would be a bit tougher than that to retain the use of the other gauges on the left.
  5. 75Maverick
    Phoenix AZ
    1975 Maverick
    Is it stock or modified?
  6. black396
    black396 Member
    florida
    Comet
    The 69 Chevelle has a round pod that contains a tach, and all the usual gauges. about the same size a the Mav.
    Charles
  7. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i like the idea, would look pretty good.
  8. courier11sec
    courier11sec Member
    Tucson, AZ
    I think, and I may be wrong, but from the picture posted I assumed he's after a bone stock look using the original fuel gauge and indicator lights. Is that right?
  9. bmcdaniel
    I looked at doing that but my tach was too deep, would've had to butcher the circuit board on the back of the cluster.
  10. 75Maverick
    Phoenix AZ
    1975 Maverick
    Yah I would like to preserve everything on it and keep it looking stock.
    Looking forward to blown's tach setup :D
  11. 71gold
    maybe like this...
  12. 75Maverick
    Phoenix AZ
    1975 Maverick
    I'm more interested in a stock look, but that looks cool! Where did you get that from?
  13. 71gold
    "dakota digital" made them for me (y) ...frank...
  14. Stefan
    Montreal, QC
    I think Charlie did something similar with analog gauges.
  15. squeal1
    squeal1 Out To Have Fun
    Evansville, IN
    72 Maverick Semi Mod, 75 Project
    I put a tach over there and I moved my fuel gauge down with my other gauges....
