69 1/2 mav whats diff on them ?
Discussion in 'General Maverick/Comet' started by MaverickGrabber, Nov 9, 2004.
  1. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    think some of the frontend parts but like what ?? rearview mirror is diff
    going to do some brake work and i have a set of drum spindels with all new parts think they came off a 69 1/2 or 70 that ward has ...was just going to hang them on ball joints the same ??
  2. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    I don't think that mirior is factory.
  3. MaverickGrabber
    Cardington, ohio
    if not its a good fit
  4. Maverick73
    Lakeland, FL
    Looks that way.
  5. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Is it a 69 1/2 with ignition on the dash?
  6. Craig Selvey
    That mirror is off of an older car.
    Differences:
    Key on the dash...not on the column.
    Horn ring on steering column instead of a horn pad.
    Metal data tag on the door instead of a data sticker on the door jamb.
    Different type of sticker located on trunk lid not found on any other year of Maverick
  7. Mavaholic
    What sticker on the trunk lid?
  8. Craig Selvey
    A silver sticker located inside. Something about '"Federal" regulations or something. They came on all Ford's in 1969.
  9. Acornridgeman
    Wisconsin
    68-69 Ford's and Mercury's had them. I remember them from my Cougar building days. Called a "Safety Act" sticker. Ford part #C8AB-6220472-A
    Jim Osborne reproduces it.
  10. Mavaholic
    I'll have to go check out mine.
  11. Mavaholic
    None on mine. Although the trunk lid looks original as well as the paint on the inside, nobody knows for sure. This a a California car. Maybe they didnt have them.
  12. Craig Selvey
    Dennis:
    Does it have the funky California Emmissions gas tank with all the vapor lines running to it?
  13. MaverickGrabber
    Cardington, ohio
    so would i be able to just hang the spindals i have on it ?? there off a newer mav
  14. Mavaholic
    yup............
  15. Craig Selvey
    I had one of those cars. The amazing trail of vacuum and vapor lines coming out of the tank and going under the car is amazing!!
    Also amazing is the fact tha car has made it all the way from the left coast to Maryland somewhere in its life.
