Busy day today ...
Discussion in 'Technical' started by dmhines, Apr 23, 2005.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Took on a couple of projects today on the 1974 Maverick ...
    1. Got the 1977 Duraspark ignition installed and working.
    2. Removed the EGR carb plate and installed the non-EGR plate on the intake.
    3. Modified a 1977 carb to work with the non-EGR plate. The bolts are closer on the non-EGR plate. Only problem is now I don't have any gaskets that fit the carb so I need to get some 1970 250 6-cylinder carb gaskets. I used some copper gasket maker to get it running.
    4. Removed all the vacuum hoses that looked like I don't need anymore. I left one for the distributor and one for the A/C. Looks like there is already a hard line going to the C4 so I didn't mess with that.
    The car runs fine if I hold down the accellerator pedal ... It will not idle at all. Perhaps without true carb gaskets its got to much of a vaccuum leak. Also the PCV hose is dry rotted so that may be leaking as well ...
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I try to keep a sheet of gasket material around for those times when you don't have or can't get a gasket. Just make an outline on the material and cut to fit with a razor knife.
  3. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    Dan what was involved in swaping in the Duraspark? Thanks Russ
  4. dmhines
    Cumming, GA
    I used all the original Duraspark harnesses and distributor from a 77 Maverick. I found a tip on a website saying to use the Throttle Solenoid Connector for power ....
    I don't drive the car in the rain so I don't use the wipers or the washers so removing the tank was no big deal ...
  5. Jamie Miles
    Alto, GA
    I've had a few
    ford84stepside, where do you get these sheets of gasket material? I could have used something like that several times now...
  6. maverick1970
    maverick1970 MCG State Rep
    Missouri
    You can get sheet gasket material at any fine auto parts store.(y)
  7. dmhines
    Cumming, GA
    Nobody had the gaskets in stock .. guess there ain't many requests for 1970 Ford 250 carb gaskets. I ordered them and also bought a sheet of gasket material. Got the carb sealed up and put on a new PCV hose ... runs great now ..
  8. ford84stepside
    Berry Alabama
    Ditto whats above. I get mine at the local parts store, comes in differnt thickness from paper thin to card board thick. I just get about a foot or so off of the roll when I buy it. Last time I used it was to make a side cover gasket on a Kawasaki 4 wheeler, worked like a charm, stopped a massive oil leak from around the cover.
  9. dmhines
    Cumming, GA
    They had the rolls at Advance Auto ... $5 for about a 2 foot roll .. about 1 foot wide. They just had two types ... the typical rubbery paper or cork ...
  10. ford84stepside
    Berry Alabama
    My local guy stocks about 4 thickness in the paper and 2 or 3 in the cork. He also stocks semi parts so that may be why he has a bigger selection.
