Question on roof insulation (inside headliner)
Discussion in 'General Maverick/Comet' started by Popbumper, May 7, 2012.
  1. Popbumper
    Popbumper PINTO unashamed
    Dallas, Texas
    Hi all:
    Hoping for some guidance here. After removing my headliner, I found the old insulation on the inside of the roof to be - well, "less than desirable" - so I renoved it in hopes of replacing it with superior/new material.
    For anyone that has pulled and installed a new headliner themselves, WHAT types of insulation/sources have they used to replace the old insulation? Thanks!!
    Chris
  2. rthomas771
  3. Dave B
    I used Dynamat.
  4. blugene
    I'm gonna be using the Peel and Seal this week.. I got it all preped and intended to go to Lowes but it's 25 miles away so I decided to wait till I needed more stuff while I'm there..
    If you need Upholstery Trim and or supplies, try American Trim & Upholstery Supply, L.L.C. I got my vinyl top and glue from them.
    www.atrim.com
  5. Joe Dirt
    Mines done in peel and seal
  6. pegleg1858
    pegleg1858 Member
    kentucky
    69 1/2 maverick
    Isn't a lot of that old headliner insulation asbestose?
  7. Dave B
    Asbestos, not in a Maverick.
  8. mercgt73
    mercgt73 Member
  9. Popbumper
    Dallas, Texas
    Exactly......to clarify, I have already applied FatMat Rattletrap extreme, but I was hoping to add another layer of material for heat reflectance as well. Was wondering what people were doing along those lines.
    Chris
  10. Bob Wiken
    Fayetteville, Arkansas
    I used 1/4 inch foam glued to the roof. It came from a appolstery shop
  11. Danny Morrison
    Danny Morrison Member
    Martinsville, VA
    1972 Grabber
    If you know anyone that does Heating and Cooling work, they will probably sell you a piece of the insulation that goes on the inside of metal ductwork. About 1/2" thick. Worked great on my Maverick!
