Proper Flywheel Removal Procedure
Discussion in 'Other Automotive Tech & Talk' started by facelessnumber, Sep 20, 2010.
  1. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    The following demonstration takes place on a 1971 Ford Pinto, however the tools and methods outlined here can apply to virtually any automobile. When armed with the knowledge you will obtain here, the next time your mother-in-law's car needs a clutch, you will be ready.
    Step 1:
    Move the vehicle to a suitable work area. A kudzu jungle is not ideal.
    Step 2:
    Carefully position the vehicle for optimal access to the flywheel. If a rotisserie is not available, earth moving equipment may be substituted.
    Step 3:
    Obtain the correct tools. Always remember, using the right tool for the job makes any project safer, easier and more enjoyable.
    Step 4:
    [​IMG] [​IMG]
    Gently peel away any piece of the vehicle that is not a flywheel.
    Pro Tip: It helps to have a little captain in you.
    Step 5:
    [​IMG] [​IMG] [​IMG]
    Take a step back and admire your work. Congratulations, you are now a junior mechanic! You can save thousands of dollars by making simple automotive repairs yourself!
    Step 6:
    [​IMG] [​IMG]
    Clean up your work area!
    Step 7:
    Installation is reverse of removal.
  2. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    :rofl2: :rofl2: :rofl2: :rofl2: :rofl2: :rofl2:
    i never knew it was so easy
  3. mercgt73
    mercgt73 Member
    Very nicely done! Your ASE Engine Repair certificate is in the mail! :clap:
  4. CaptainComet
    In the Kudzu jungle ... no one can hear you scream ...
    especially if you are a Ford Pinto.
  5. justin has a 74
    kentucky
    I was thinking at the bottom of a cerial box!:biglaugh:
    Looks like fun!:bananaman
  6. facelessnumber
    Memphis, TN
    '71 Grabber
    Cereal box hell! I cut that sucker out the back of Mad Magazine.
