What is your vote? Headers or not?
Discussion in 'General Maverick/Comet' started by Rev Ron, May 22, 2012.
  1. Rev Ron
    Rev Ron Member
    Dalzell, SC
    Comet GT
    I am building my 71 Comet GT. It has a nice 5.0 roller motor with a 5 speed out of a Cobra. However, the headers are a real pain! They are in the way of the power steering ram... make it hard to get to spark plugs... right up against my tranny... leak and come loose. All this and more. Are they really worth it? I want my Comet to be a good daily driver that has a little kick... how much horsepower do I lose or gain? Other thoughts?
  2. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    I do not have any answers, but I was just having the same debate after removing my temporary exhaust and remembering that I'm going to have to bend the collectors pretty good to get them running parallel to each other and the road.
  3. scooper77515
    I have long tube hooker headers. They are GREAT! But if I was to do it again, and I wasn't drag racing, I would stick with manifolds.
    Been thinking of going back to manifolds, anyway...
    Headers are a biatch!
    And shorties aren't much better. They just get in the way elsewhere.
  4. 71gold
    I think here's your answer...:yup:
  5. 71gold
    ...at wide open throttle...:yup:
  6. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    After spending 2.5 hours last night bending,beating and denting the drivers side hooker header on im thinking it was a mistake, but when i hear them I'll change my mind. tonight its the passengers side "yea"
  7. Resto
    Resto Benders Evil Twin
    Yuma AZ
    If youre not too concerned with HP, and it is a daily driver, Why not go with shorties? It will still have enough KICK.:)
  8. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    I chose shorties to avoid draggin' on speed bumps. I expect the difference between shorties and long tubes shows up at RPMs higher than what I'd use on the steet.
  9. jayss10
    jayss10 This is Minerva
    INDIANA
    1971 MAVERICK,73 GRABER CLONE
    i bought hedman 15/8th headers went right in with no dings,or touching anywhere, so im headers for sure....
  10. Tannersg1
    Tannersg1 Member
    Classified
    I'm gonna be mad if i have to beat up my Ceramic coated 6901's to get them on!
  11. 71gold
    I got the...bare metal...headers, beat/cut/welded them to fit, then sent them to be coated...
    now i have...coated stock manifolds.:thumbs2:
  12. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    Oooh just wait untill you hit a speed bump with them:mad:
    Honestly with long tubes if you run into a big enough speed bump it will actually stop your car on the collectors..
    Im getting ready too cut the collectors off of my long tubes and just use a reducer and weld them too my exhaust pipes.
    But I gotta admit they sure do sound good :thumbs2:
  13. olerodder
    olerodder Member
    NorCal
    Headers can make HP, but on a street motor making less than 450hp there is not need to go any bigger than 1-5/8 primary tubes..............until you get upwards of 500/600hp then go with 1-3/4 or 1-7/8" primary. Just a case of point is that my 640hp motor uses 1-3/4" primary then stepped to 1-7/8".
    Bigger is not always better....................IMHO
    So why beat your headers to death, just get smaller primary tubes......and if those don't fit then BUILD YOUR OWN!
  14. bmcdaniel
    Hmmm, I have the same combination except for the power steering. Wonder why I never had any of those problems? How are the headers up against the trans? They have to be outside of the bellhousing which is a lot wider than the trans.
  15. olerodder
    olerodder Member
    NorCal
    I certainly don't want to hyjack this thread but I have a couple of questions.
    What are the main areas of interferance with long tube headers?
    NOW, if someone in The Bay Area would like to donate their 302 car for a week of so I would be willing to build a set of headers....Long Tube that would fit correctly without denting/welding/cutting/bending etc., and do it for just the cost of tubing and flange. I'll bet I could make a set of headers that would out perform anything that is sold on the market today.....for say
    less than a 450hp motor......................and only be slightly more money.
    The first car would act as the mock-up.........from that I would make my jig or multipul jigs...........................and go from there.
    Any Takers?????????????????????????????
    Sometimes you guys drive me crazy with talk about headers............it just takes a little work and you have a really nice set...............and build them yourself...........................................or I will!
