1971 Mustang Center Console ....
Discussion in 'General Maverick/Comet' started by dmhines, Aug 4, 2004.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Got a 71 Mustang Console today .. (good idea Seth!) and it looks pretty good. I need a bigger boot or a GM style cover for the shifter hole. I was hoping the Maverick consollete clock-delete insert would be the same size as the Mustang but looks like the Mustang clock was larger. I am thinking of a way to dress of up the rear of the console where it just kinda ends under the front package tray.
  2. dmhines
    Cumming, GA
  3. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    looks good !!!
  4. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Looks excellent. Dang man, you have one of the nicest Mavericks on this site...
  5. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    The front...
    ...DM, I have a triple gauge bezel hanging from under the dash
    to 'cover' up that sudden ending.
    I am going to shave a bit off of the very back of mine to make it
    sit down flush. Mine has a slight gap in the middle.
    Why don't you hook up your clock?
    Supposedly having a jeweler install quartz movement is the way to
    go on vintage clocks.
    Seth
  6. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    Dan looks good.
  7. dmhines
    Cumming, GA
    Clock would be cool .. but since I keep the battery disconnected I would always be resetting it. Plus I needed something to do with this NOS Maverick Consollet block-off plate I had. I bought some of the metal-foil stuff to do my door panels and applied it to the Maverick Logo on the block-off plate to make it stand out. Here is how the shifter is supposed to look in the console. Also - here is the original Mustang block off plate ...
    P.S. There are guys on the board with nicer Mavericks and Comets than me ... but I am trying .... :)
    Seth .. you have a picture of the triple guage setup?
  8. CornedBeef4.6L
    no longer here
    Get a clock that has a seperate battery.:smash: The clock idea sounds like it would fit the bill, have one custom made if need be by a jewler or clock smith.
  9. dmhines
    Cumming, GA
    Here's another view ... I have it in with masking tape until I make a larger plate to mount it properly ....
  10. littleredtoy
    littleredtoy Seth
    '74 Comet GT
    DM-
    I will snap a pic for you this weekend, don't think that I will
    be back to the garage b4 then.
    Seth
  11. T.L.
    T.L. Banned
    Southern Colorado
    I think it looks much better without the clock. Love the emblem trick; looks like it's supposed to be like that...
  12. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    I agree, it looks great with the emblem.
    -Corbin
  13. dmhines
    Cumming, GA
  14. GrabberJoe
    GrabberJoe Member
    Brooklyn, Michigan
    1974 Maverick Grabber
    Console Mod.
    I put that console in my first '74 Maverick Grabber in 1980. I used the Mustang clock and glued the word Maverick on the end of the console. My car was an autmatic and the shifter fit that hole perfectly. You may need to use a larger boot mabe from a newer car to fill the hole. You could also move you gauge cluster to the back of the console behind the clock. It would look awsome at nite when lite up! I had an 8 track tape deck mounted under the dash just to the right of the radio untill 1983! I love you car!! The Maverick I have now has a perfect deluxe interior with a bench seat that will stay that way. If it would have been ware out I would have changed it:D
