Changing from points to electronic
Discussion in 'Technical' started by Dean Deeter, Nov 6, 2005.
  1. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    Hey everyone I am think about changing my 74 comet from points to electronic. Any sujections would help. It is a 302 with a mild cam and headers. This car is driven very little we use it mosty for cruzins no racing just pleasure. What donor cars or engines do I need,or do you suggest new parts. I also am goint to change my wife 74 mav from a 200 to a 250 is there electronic parts available for this motor. It will be a daily driver. Thanks for your help. I will be gone for a couple of hours will check back this afternoon. Dean
  2. 71gold
    do a search on "pertronix"...been happy with it in a bunch of cars, trucks and motorcycles...frank...:bouncy:
  3. scooper77515
    Isn't the pertronix something you can just drop into the existing distributor, or am I thinking of something else...?
    I saw a small box that you pull the points out, and replace with this little box. I will see if I can find where that was and put it up here, unless it is the Pertronix everyone is talking about.
  4. 71gold
    it is that simple :yup: ...5 min. job (y) ... even Terry could do it in 10 mins :huh: ....frank...:bouncy:
  5. Jamie Miles
    Alto, GA
    I've had a few
    Yea Scott, that's the Pertronix. I am running the Duraspark II ignition and am extreamly happy with it. It gives you a little hotter spark and retards the ignition autmatically when turning the motor over which makes the car start very easily when it's hot. I got all my parts from the junk yard.
    You really can't go wrong with either. The Pertronix is easiest to install. The Duraspark II you gotta replace your distributor, mount the module somewhere under the hood and then wire it up. It's still not really hard though. I could convert a car to Duraspark in less then 30 minutes with all the parts in hand.
  6. scooper77515
    OK guys, I always ask this...Jegs or Summitt part numbers, please?
    I have found a couple, but they are Jeg's off-brand or non-pertronix, but likely the same thing. price?
    My points are new, and work fine, but I know how they are...
  7. Comet155
    Comet155 Member
    Jeg's part # 751-1281
    Summit # PNX-1281
    That's for the original Ignitor unit. Double check with the companies to make sure the numbers are up to date. Sometimes they change numbers in newer catalogs.
  8. 71gold
    i did a search on the net...pertronix...pn# 91281... $89.00
    ...frank...:bouncy:
  9. Comet155
    Comet155 Member
    Pertronix Ignitor # 1281 Electronic Ignition Conversion Kit,Ford V-8 1974-57
    Other products by Pertronix Ignitor
    Share your own customer images
    td.productLabel { font-weight: bold; text-align: right; white-space: nowrap; vertical-align: top; padding-right: 5px; } table.product { border: 0px; padding: 0px; border-collapse: collapse; }Price:$63.95 Availability: Usually ships in 1-2 business days. Ships from and sold by Warehouse Auto Parts.
  10. Dean Deeter
    Dean Deeter Member
    So if I understand you guys corectly I do not have to replace the distr. with the Pertronix system and the performance is good?? DeanQUOTE=Comet155][​IMG]
    td.productLabel { font-weight: bold; text-align: right; white-space: nowrap; vertical-align: top; padding-right: 5px; } table.product { border: 0px; padding: 0px; border-collapse: collapse; }Price:$63.95 Availability: Usually ships in 1-2 business days. Ships from and sold by Warehouse Auto Parts.[/QUOTE]
  11. Jamie Miles
    Alto, GA
    I've had a few
  12. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
  13. stmanser
    Davenport, Iowa
    i bought a complete MSD ignition system.... Pro bilelt distributor... msd 6a box... blaster SS coil and 8.8 msd wires... for about 600 or so... and i gained at least .4-.6 in the 1/4 mile
  14. sierra grabber
    sierra grabber Certifiable
    northern nevada
    ummm, two things t.l. with the stock dist and a pertronix you can go back to points in an emergency. the second is H.E.I. sucks big time. definately something gm can keep.:2cents:
  15. Dean Deeter
    Dean Deeter Member
    What I can see is the hei will be at least 200 bills, the pertronix will be 100 at most. For the application I want I believe this is the way I will go. Dean
