spring compressors
Discussion in 'Technical' started by 71nogo, Jul 13, 2010.
  1. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    im doing something wrong. when i lower the unit into the spring to remove my front coil's, i wind up spinning the screw rod into the upper control arm. i have tried a couple of different areas but it always works out the same. whats going wrong?
  2. maverick75
    Removal & Installation
  3. rthomas771
    Turn the tool around. I know it's slower but it works. You don't want to use air wrench on the spring compressor, the hammering will kill the threads.
  4. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    that did not work! the bolt just spins on thru. should'nt there be a nut to thi unit to hold in place? then it would tighten the hole thing together.
  5. blugene
    There are several types of compressors. Not sure which one you have.
  6. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    hey gene, i have "OEM 27035". I HAVE THE SPRING COMPRESSED. im trying to figure out how to remove the upper control arm so i can release it.:cry:
  7. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    I built a spacer out of an old bicycle seat post for my compressor. Otherwise, you are correct in that the bolt hits the spring perch.
  8. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    IT"S OUT!:thumbs2:
  9. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    Out of everything i have taken off of this car, that by far was the hardest.:dance:
  10. blugene
    Sorry, I got busy..
    I personaly think it is the hardest thing to remove.
