2.3 turbo swap
Discussion in 'New Members Forum' started by slidinwildman, May 7, 2011.
  1. slidinwildman
    slidinwildman New Member
    vacaville ,ca
    73 pinto
    im in the middle of a swap for my car . I got the car together it fired up im looking for some info
    heres the parts that i got:
    2555 lph walbro(inline)
    adjustable 30-100 psi fpr(fuel pressue regulator)
    stock 85 turbo coupe ecu
    stock # 35 injectors
    2-1/2 inlet& outlet saab inter cooler
    stock 3/8 fuel lines
    here the problems :
    pluseing at the fpr
    also the pressure is hard to adjust
    the pressure is steady untill it starts to
    starve for fuel as if its lacking flow- but i ckecked it -
    looks all good to me :hmmm:
    becuase of this problem the car wont drive
    at 30 mph falls on it face ( its rich )
    ive got a whole lot of other stuff but im really
    looking for the answers to what fpr should i be useing
    also what did you use for your fuel pump brand ect.....
    im not sure what im missing here so any usefull info is a great
    help
  2. 71gold
    Hi :Welcome::Handshake
    i would think your questions would be better answered on a...2.3 turbo swap...web site...
    ...Frank...
  3. injectedmav
    injectedmav Member
    Georgia
    Have you verified with a gauge that it is indeed starving for fuel at 30mph? Need a little more detail on your install before anyone can answer a specific question about it.
  4. Joe Dirt
    Do you have the correct small vam?
  5. 71gold
    is it in the...limp mode?
  6. injectedmav
    injectedmav Member
    Georgia
    255lph pump and 100psi fuel pressure on a 35lb/hr injector would definitely run rich if you're running an otherwise stock 2.3l turbo motor especially if the turbo is stock as well. 85 should be non-intercooled and the wastegate opening pressure should only be 5-7psi(if memory serves). sounds like way too much fuel and nowhere near enough air.
  7. maverick75
    :Welcome: I have a friend in Vacaville :thumbs2:
  8. 4cfed
    4cfed Member
    Belfast, ME
    76 mercury comet
    definatly all very good ideas.
    im not sure about limp mode. the only reason why i say this is i used to have a 88 dodge spirit 2.5l tic that had ALOT of work done to it and when thed MAP sensor (i should of had a 3 bar GM map) would crap out the thing would go into limp mode and it just didnt have enough power to get out of it own way. now there may be other things contributingthat woiuld cause it to be in limp mode then make it fall on its face. but at 30 mph wouldnt it be a rpm issue anyway not really a mph? you would have a higher volume of air going down the road then sitting in your garage or driveway. if he has a turbo coupe vam then it should be the bigger/better one anyways. do you have an aftermarket BOV on this car? if you do it may be in the wrong spot. if you have one on it put the bov on the lower pipe on the intake side of the intercooler.
    hope im not being the forum idiot and some of this helps you.
    Devin. p
