What do you regret doing to your maverick/comet
Discussion in 'General Maverick/Comet' started by Zooomzoomguy, Feb 29, 2012.
  1. blugene
    Same here.. Took mine apart and it may never go back together.. I always plan to do something and it never happens. I have too many excusses and old bones..
  2. darren
    I edit my first reply. This is dead on. I totally forgot. Yes I should have taken a lot more pics along the way. Especially the body and paint. Also I should have used my wifes high end Canon instead of my older Kodak Digital for quality reasons. This I would suggest to all doing this type of work on a project!!!! Take more pics than you think are needed and monitor the quality of them.
  3. simple man
    simple man Member
    Bunnell,Florida
    Oh, so absolutely true! :)
  4. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    right now its paying too much up front for the thing. There ended up being a lot of more problems with the rear quarters then I had thought. I think I payed about 30% to much for the car.
  5. jhohlfeld
    jhohlfeld Member
    Lexington KY
    71 Maverick Grabber, Isaac's 76 Maverick
    I regret selling my first one for sure!!
  6. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    i regret trying to use the eec-v .. went to the ezefi retrofit and a baumann tcu...
  7. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    X-Pipe
    I regret using an X-pipe in my exhaust system. Not only won't the transmission come down without taking the exhaust apart but neither will the trans support cross member. Can't adjust the modulator confidently with the cross member in place. :mad:
    Gonna see if the x-pipe can be eliminated so as to allow the transmission to come down with the exhaust pipes in place.
  8. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    I had the exhaust shop put ball and socket connections on the back of a x pipe on a Mustang i had.Sort of like the original H pipe.Just undid it at the headers and the rear of the X,i could drop it out of the way in minutes. Just a idea
  9. Jsarnold
    '72 Sprint
    I also have connectors just ahead of the mufflers so I can take the exhaust pipes down by unbolting them at the headers and at those connectors. But, I have shortie headers and getting the bolts off and on the headers by myself requires a LOT of contorted positions and repeated trips up under the hood and back under the car. It takes about an hour of frustration getting them off and another hour putting them back on. It would be a lot easier if I had a lift.
    I've had the exhaust pipes off and on more times than I expected and now I need to adjust the modulator (again) and replace the governor. :mad: Time to toss the x-pipe. Just something to think about for guys that work alone with the car on jack stands.
    Some kind of easy off/easy on connectors ahead of the mufflers are a must but with the DT shortie headers they aren't the whole solution.
  10. Jsarnold
    '72 Sprint
    Shoulda Bought a Memory Tach with Shift Light
    Regret not buying a memory tach with built in shift light. I have a new tach and an external memory device but no shift light. When running at the strip, I find I'm too busy driving and looking for the traps to focus on the tach. Shift light would be a nice assist.
  11. Demmitt
    Demmitt nutz and boltz
    Sandsprings, Oklahoma,
    1976 2 door, 1969.5 2 DOOR
    drilling to many holes in the floor pans and trans hump (3 different shifters and 3 different bucket seats) lots of holes.:cry:
  12. Derek 5oComet
    Didn't realize you had shortys.That definately makes it more difficult
  13. h2o
    h2o Mad Mav Man
    mexico city
    1973 ford maverick gt 289 v8
    Regret selling my first one.
    Regret not taking out the steering box to rebuild it when the enngine was out, it was a terrible pain in the nuts to take out with the engine in the car!:cry:
