AOD plz help
Discussion in 'Transmissions' started by classic ccg, May 22, 2013.
  1. classic ccg
    ringgold GA
    72 maverick
    I got it in, but it looks to be far forward. It will go all the way back on the drive shaft, then the trany mounts won't line up, but if it's that far up it lines up fine. I think I'm still having bad luck with this car lol.
  2. classic ccg
    ringgold GA
    72 maverick
  3. Bryant
    hard to tell what your asking.
    it looks like the aod is on the stock crossmember. this will put the trans to far forward in the car.
    you will need a custom transmission crossmember to make the aod work. frank (71gold) sells them.
  4. classic ccg
    ringgold GA
    72 maverick
    Man thank you I just sent him a pm. So I think this is the c4 one crossmember
  5. 71gold
    71gold Frank Cooper
    are your motor mount stands on the correct side?
  6. Krazy Comet
    Be sure you connect the TV cable on that AOD, it'll be toast in short order if you don't...
  7. classic ccg
    ringgold GA
    72 maverick
    I think so when I pulled them off the parts car I put them on my car
  8. classic ccg
    ringgold GA
    72 maverick
    I'm going to do the install myself and the tow it to a transmission shop jus to be safe
