I think I found my engine problem...
Discussion in 'General Maverick/Comet' started by bmcdaniel, Jun 5, 2006.
  1. bmcdaniel
    Some of you that were at Carlisle last weekend know that I didn't have my car there due to an engine problem. I had just put in a mostly new engine last week. I reused my 347 crank, rods and pistons from my old motor that developed a crack on one of the lower cylinder skirts. The parts only had about 3000 miles on them. Prelubed the engine, started right up, 50 psi oil pressure. While I adjusted the ignition timing it started making a loud clanging noise then froze up.
    Tonight I jacked up the car to drain the oil and pull the pan off. While jacking I saw water running out the far side of the engine. When I looked around at the other side, there's a connecting rod is sticking out through the oil pan! :( And the water was coming out of the pan so I guess my "new" block is shot too. If I get the pan off tomorrow night I'll post a couple pictures.
  2. Jamie Miles
    Alto, GA
    I've had a few
    Man that sucks. :( I feel for ya.
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Bummer! I assume it was the small end of the rod that gave way.
  4. bmcdaniel
    Could be, it looks like the big end with the cap still attached that is sticking through the pan. Maybe the crank broke, too.
  5. don graham
    sorry to hear that. :cry:
  6. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Sorry to hear that:( Did you reassemble it or did a machine shop? If it was a machine shop I would take it back and see what they can do for ya:Handshake What brand rod did you have?
  7. Mercurycruizers
    Venetia, PA
    I feel for ya! That really sucks!!
  8. Mavaholic
    Bummer!!!! At least it didnt happen on your way to Carlisle.
  9. bmcdaniel
    The crank, rods, pistons are Coast High/Probe parts. The crank is (was) a Chinese cast piece. Think I'll go with forged parts next time!
  10. Cleaver
    Cleaver Member
    MD
    Chel
    Sorry to hear about that. Kind of get a sick feeling way down deep when you hear those loud raps because you know what is coming next.......Post some pics of the post-mortem. It will be interesting to see if you can determine what gave out first.
    Cleaver
  11. 393mark
    393mark Member
    Palm Harbor Fl
    1970 W/393
    Sorry about your engine hope you can get a new one soon
  12. scooper77515
    Done that once...luckily it was on a VW beetle. Still hurts, though :cry:
  13. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    That sucks,, hoped it would not be that bad.
    Dan
  14. Jean Doll
    Palmerton, PA
    Oh, how I hate to hear about these kinds of things.:( Just be thankful it didn't happen 100 miles away from home. Hope you get it back up and running soon.
  15. bmcdaniel
    Yeah, the way my luck usually runs I woulda been half way to Kentucky next month when it let go.
