Dim Dash Lights
Discussion in 'Technical' started by indyman13, Jan 2, 2008.
  1. indyman13
    indyman13 Member
    Little Rock, Arkansas
    My dash lights seem really dim even when the interior control (on the headlight switch) is turned up all the way. Had the dash out a few weeks ago for some other work and cleaned 15 years worth of dust off them but no appreciable difference.
    Alternator is probably working good because no alt light comes on and there's no noticable difference in brightness when the engine is idling or turning a couple of thousand rpm.
    Voltage regulator? Switch to Krypton or Halogen? Live with it?
  2. Comet155
    Comet155 Member
  3. indyman13
    indyman13 Member
    Thanks, that gets me going in the right direction.
  4. Comet155
    Comet155 Member
    No prob. Now take a look at my nutty shift light problem.
    See what you make of that!
  5. gdemopesq
    gdemopesq MOTOR CITY MAV
    Michigan
    72 Maverick 302
    I think its the headlight switch
    The head light switch controls the dimness. A bulb is burned or it is not. Auto Zone has them for about 10 bucks
  6. PaulS
    The switsh is working..... the lights come on.
    The factory bulbs are very dim - there is a replacement that is brighter.
  7. gdemopesq
    Michigan
    72 Maverick 302
    the switch has a regulator
    the switch has a regulator that is probably not working properly. i have the same problem and I am getting a new switch today. i will let you know.
  8. PaulS
    gdemopesq,
    The dash lights in Comets and Mavericks are infamous for being dim. The cure is to use a bulb of the same size that is brighter. Then the regulator (which is a wire wound resistor) can dim them or allow them to be bright. Have you bought your new switch yet? did it make your lights brighter? We can get the part number of the bulbs if you need it.
  9. Shinysideup
    Shinysideup Chillin the most
    town
    car
    I tried new bulbs without much difference. I regrounded the lights and much better!
  10. Bob Wiken
    Fayetteville, Arkansas
    spork1o1 has or had some sets of w5w's.
    There are 20 bulbs in the package and he charged $6 shipping inc.
    you might PM him
  11. gdemopesq
    Michigan
    72 Maverick 302
    Lights
    I bought a new switch with dimmer and will try tonight to put it in. I will let you guys know. I also put white backing on the gauges and ordered red LED's. All this should help.
    Super Bright LEDs-LED's
    Auto Zone had the headlight switches in stock
  12. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Your dimmer is not gonna work with those LEDs...
  13. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    Why would the dimmer not work?:hmmm:
  14. Jamie Miles
    Alto, GA
    I've had a few
    The dimmer will work fine... Dan Hines did the same thing to the '74 he used to have, except he put blue LED's in with the white face gauge overlays. It looked good. Still wasn't super bright, but it was better then stock.
  15. facelessnumber
    Memphis, TN
    '71 Grabber
    My understanding is that the LEDs don't get dimmer or brighter, they're just off or on. I've observed this on another cluster with LEDs. the dimmer didn't work, although it looked great! Are these LEDs special in some way?
