1970 Carburetor/ Acceleration Problems: Please Help!!
Discussion in 'Technical' started by dotfrost, Nov 17, 2010.
  1. dotfrost
    dotfrost Member
    Mesa, Arizona
    My dad and I rebuilt the carburetor on my 1970 maverick (Straight 6, 3.3L) a couple months ago, but the thing is still problematic. It was leaking all over the place about two weeks after from the back-right side (by the exhaust manifold).
    Now, there's a hiccup in the acceleration. When I push the pedal down to the floor, it gags and seems just about ready to stall. I have no idea what the HeCk is HaPpeNiNg!!! Please Help!!
    -David from AZ
  2. PaulS
    It sounds like it could be the accelerator pump not working properly. A missing check-ball or ruptured pump cup?
  3. craigs1970mav
    craigs1970mav Member
    Virginia Beach
    1970 Maverick, 1985 Mustang GT convertible
    Carb problems
    Having the SAME EXACT problems with my 1970 maverick 200I6. The carter carb just sucks. I say this after buying a new rebuilt one, replacing the rubber fuel lines and draining/cleaning out the gas tank. The carb just works when it wants to. Help anyone?
  4. GRABBER70
    GRABBER70 Member
    wisconsin
    1970 maverick grabber
    :anyone: i have the exact problem! i have the 250 I6 in mine and when i hit it, the motor just about dies beacause it lags so bad. ive heard maybe vacuum advanced problems?? im going to try a new carb first. :hmmm: if that doesnt work im replaced the vacuum advance. help??
  5. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    One thing I would make sure of is that you have enough spark for all the fuel when flooring it. Upgrade to an electronic ignition and coil, new plugs and all that fun stuff. I know when I installed to 2bbl weber on my 200 it bogged down when the second jet kicked in. But the problem seemed to stop once I upgraded the ignition system. Maybe no your problem, but worth a shot if you haven't changed to ignition.
  6. GRABBER70
    GRABBER70 Member
    wisconsin
    i put new accel wires, new plugs, new cap,and new rotor in car a while ago but still has the lag.
  7. doncomfort
    chillicothe oh
    Ive had that problem with mine for many years and just learned to live with it. But last year I got to tinkering around and opened up my point gap a little, it made a big difference! Its just a matter of time before I go to a Duraspark setup.
  8. adam 72
    adam 72 Member
    New Mexico
    1972 maverick
    Maybe the points?
  9. 71Mavrk
    71Mavrk Member
    Nevada
    David,
    Can you describe your problems a little better? You say it was leaking all over the place and then you point to just one area. Was it gasoline or a vacuum leak?
    When you say it gags, does it hesitate and nearly stall or does it backfire through the carburetor?
    Is this a manual or automatic.
    Are you using the Holley or the Carter carb?
    What if any modifications have you done to the car?
    Micah
  10. 71Mavrk
    71Mavrk Member
    Nevada
    Sorry about that. Gets a bit confusing when people reactivate old threads to get answers to their new question.
  11. Gundy26
    Gundy26 Member
    Maverick
    We ended up backing off the idle solenoid, and adjusted the choke and air mixture screw.
  12. GRABBER70
    GRABBER70 Member
    wisconsin
    if your having that acceleration problem put a brand new carb and distributor in it. I had the exact problem with my 250 i6 and as soon as I put a crab and distributor it was night and day difference. fixes the problem and now she's a one wheel ground pounder lol :chirp::thumbs2:
  13. first maverick
    first maverick New Member
    Phoenix, AZ
    1970 maverick
    I'm having a similar issue with my 70. Seems like I can advance the timing and solve the "stalling" issue but then its hard to start and the idle isn't great. I have adjusted the carb about every way possible. I have new plugs, wires, cap. I'm chalking it up to a junk carb. I'm just debating whether I will be dropping in a 302 or getting ahead and intake and putting on a turbo.
    Joe-Phoenix
