Vapor valve how much!! Now!!??
Discussion in 'Technical' started by flynbrd, Jun 15, 2011.
  1. flynbrd
    flynbrd Member
    So anyone know if we can adapt a different vapor valve in? The 76 maverick gas tank vapor valve was 10$ now its almost 40$:slap:
  2. 71gold
    i get them w/grommet from the junkyard...one of thoes things i look for when i go...they come on a few different tanks...mine came from a Lincoln tank...(y)
    PM me if you can't find one...:Handshake
    ...Frank...
  3. flynbrd
    flynbrd Member
    what year lincoln? I have the 76 tank which different from my old 71 fuel tank vapor valve.
  4. injectedmav
    injectedmav Member
    Georgia
    71 should have had a cap with a screen in it, no actual valve. The later Mavericks 73-up I think, had a push in vapor/rollover valve with a sealed gas cap for evaporative emissions.
    Does yours have a retaining ring like on the sender or is it pushed into a grommet in the top of the tank?
  5. flynbrd
    flynbrd Member
    Does this help? the tank is currently in the car for test fitting.
  6. injectedmav
    injectedmav Member
    Georgia
    That one uses a push in valve with a grommet. Alot of Fords use that style and the aforementioned Lincoln, mid 70's-90 crown vics, marquis, F150's, E150's, are the ones that I can think of off the top of my head. Basically look for one used on any of those with a gas engine and with just one 1/4" port. It's definitely the push in, not the twist lok used on some 90's and up. They rarely go bad so it might be worth a trip to the salvage yard if your parts stores can't get one reasonable.
    quite often the price increases are due to low stock and supplier changes. Good luck
  7. flynbrd
    flynbrd Member
  8. injectedmav
    injectedmav Member
    Georgia
    that looks like it. $40, ouch. I would hit the salvage yard...
  9. flynbrd
    flynbrd Member
  10. 71gold
    plus...$7 shipping...:coco:
  11. 71gold
  12. injectedmav
    injectedmav Member
    Georgia
  13. injectedmav
    injectedmav Member
    Georgia
    My parts dept after their healthy markup is $55 for the correct one(the first one you listed). My cost is still around $30, special order.
    I still think the salvage yard is your best bet. you could probably get one for less than $10.
