Rear Disc, Not gonna have to cut axel housing flange...?
Discussion in 'Technical' started by Moneymaker 1, Oct 1, 2012.
  1. Moneymaker 1
    Panama City Florida
    I have read and heard that to do the rear disc swap that there is some trimming of the axel housing flange needed, though I did not see the specific reason why it had to be trimmed I am assuming it is because of some type of indent in the backing plate (can anyone shed light on the reason for cutting the flange) well the backing plates I'm using have no indent, thay are flat across, all the way, so I should not have to cut my axel flanges....right?
    Oh now I did it...thought too much, gotta have a nap!
  2. rthomas771
    This is what the back side of my backing plate looks like. See the indention for the axle flange?
  3. Moneymaker 1
    Panama City Florida
    The one I have is kinda flat, if anything it may be raised where ur's is recessed, what year is that and what's it off of?
    I've also noticed my bolts are offset too.
  4. rthomas771
    '96 Grand Marquis...what year/model is yours?
  5. Moneymaker 1
    Panama City Florida
    The numbers I ran from them come back to a 1999 Crown Vic.
  6. 71gold
    not thinking those are...CVs. what diameter is the center hole?
  7. 71gold
    the CVs are the same bolt pattern as the ...Mav. 8" axle tube flange.
  8. Moneymaker 1
    Panama City Florida
    I measured it once but I don't remember, it's dark and raining here now so I don't really want to go out and measure them now.....aww well wait....best I can tell with my Craftsman tape measure it's 2 7/8" or close.
    Here are the numbers I ran and got 1999 Crown Vic.... 3213636-U
    Google........ http://www.ropermotor.com/parts/ford/crown%20victoria/bracket/
  9. 71gold
    that is what they say...but the bolt pattern is wrong...:yup:
  10. Moneymaker 1
    Panama City Florida
    Wouldn't the bolts being offset possibly clearence the caliper better in relation to the spring? I mean it's either gonna be better or worse, could these be from a police intercepter Crown Vic thus the reason for the difference, I don't know but I'm gonna try them on my car, at least I won't have to cut the flange with these, thus my reason for this thread.
  11. 71gold
    you may run into an...E-brake cable...problem...:yup:
    those clip thingys look like...bearing retainers...:huh:
    of all the...CVs, Linc, and G.M. we've seen, none have a Disc. brake bracket like those...:hmmm:...
  12. Moneymaker 1
    Panama City Florida
    The e-brake hookup looks to be the same as the one in the pic Jeff posted, I'm hoping I can lose those clip thingys, and didn't I read someplace that some guys have redrilled holes in backing plates to offset them and get a better fit?
    Can someone measure the distance between the mounting plate holes and let me see if they match?
  13. 71gold
    I did this but ran no E-brake...:yup:
  14. 71gold
    it's the angle will be too much to route the cables...that is using the maverick E-brake system...
  15. Moneymaker 1
    Panama City Florida
    Right now my Grabber has no e-brake at all, seems the cable has been removed and the pull handle inside is screwed up so I will have to redo the whole works, maybe I can improve it then also.
