Oil in water
Discussion in 'Technical' started by Motrhd, Jan 13, 2013.
  1. Motrhd
    Motrhd Member
    1975 Maverick 302
    Working on a 1975 Maverick been sitting for almost a year...replaced manifold gaskets and rebuilt carb...got it running. Question is I seem to be getting oil in the coolant...where could it be coming from???
  2. Moneymaker 1
    Panama City Florida
    Is it oil or transmission fluid? Tran. fluid can come through the radiator cooling tank.
  3. 71gold
    :Welcome: :Handshake
    when it was sitting ,did it get cold enough to freeze...:huh:
  4. rthomas771
    Did you use sealer on the gasket around the water ports?
  5. Xaan
    Xaan Newbie
    Germany
    70`3,3
    Maybe Cylinder head/engine block crack.
  6. Motrhd
    Motrhd Member
    1975 Maverick 302
    I live in Florida so no freeze. I did use sealer around water the water ports on the manifold, even if that wasn't perfect how can water mix with oil in the manifold? There is only air and water in coolant passages..right? The radiator was repaired before I joined the mix..so maybe the transmission line is leaking into radiator. There was what appeared to be coolant mixed with oil when I changed oil, which I thought maybe came from changing the manifold. Where is the engine block drain plug..didn't see one..would like to drain and rinse the block. If the block or heads were cracked the oil would look milky?..or the engine would blow white smoke or stop running...and I have none of those.
  7. Moneymaker 1
    Panama City Florida
    What part of Florida? I am in Panama City, I ask because I think I have a radiator out there somewhere in da parts.
  8. Motrhd
    Motrhd Member
    1975 Maverick 302
    Radiator
    I'm in Orlando..might be interested in radiator as this one is tired.
  9. rthomas771
    The water port leaking between the head and intake will end up in the oil pan
  10. Motrhd
    Motrhd Member
    1975 Maverick 302
    Makes sense...but wouldn't that show as smoke or vapor lock?
  11. rthomas771
    It would if it leaked into the combustion chamber, but leaking into the lifter valley and getting into the oil pan won't
  12. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    I have a good 2 core out of my 75 I6. I think it will work with a stock 302. PM me if your interested.
  13. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    The complaint was oil in the coolant, not coolant in the oil. :huh:
  14. rthomas771
    My bad.......
  15. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
    Would the engine oil get into the oil if head or block was cracked in the right place. Engine oil pressure is normaly higher than coolant pressure.
