squeeking/squwak/scrubbing
Discussion in 'Technical' started by 71gold, Mar 14, 2013.
  1. 71gold
    pulled wheel, caliper, rotor, spindle, coil over shock and checked everything twice...left front. had this before and after alignment. I was thinking it would go away after being aligned.
    but still have this noise when applying brake (light/heavy) and going straight and turn the wheel to the left slightly. when turning back right to straight the noise stops. no noise when turning right...this is at all speeds...:huh:
    I have not ruled out it being...My Ghost...:D
  2. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Interesting... Have you tried jacking that wheel off the ground and rotating it by hand? Giving it a good "tug" in all directions?
  3. Moneymaker 1
    Panama City Florida
    I assume you checked the wheel bearings and races. :huh:
  4. Mavman72
    What type of brake set up do you have on the front of yor car Frank??
  5. 71gold
    don't have a jack...:cry:
  6. 71gold
    SSBC...:thumbs2:
  7. 71gold
    I'm turning the rotors and new bearings/seals tomorrow...:Handshake
  8. Bryant
    are you using ssbc pads? ive had problems with the pads in their kits making noise.
  9. MSmithPDX
    MSmithPDX Member
    Portland, OR
    It could just be that you turn left too much. Try making more right turns so that your wear your parts evenly!
  10. Mavman72
    Are you certain its the bearings/races??? Make certain the caliper mount on the spindle is not loose or bent.
    Check that the pads fit tightly in the calipers. Loose pads will make all sorts of weird sounds. Since they are SSBC...I assume the pads are held in place by a pair of pins like PBR calipers on a vette. Check the pins for a groove worn in em from the pad, also check the pin bores to be certain there is no slop with the pins in place. Some of these setups have an O ring in the pin bore. If yourse have em, make sure they are all there (Should be 4 of em) Also...If you have dust shields on your setup...Check em for rub marks. Rotors do flex and can contact the sheild if they are close enough to each other to begin with. Check the hub face the rotor sits on for a burr or debris that will keep it from sitting flush. (It dont take much) Good luck!!!
  11. 71gold
    yes, but they are just standard...D54 pads...:yup:
    it's just one side and this noise is loud, sounds like metal on metal.
  12. scooper77515
    No comment. Just subscribing to thread in case you figure it out, and I have the same issue after I install my ssbc brakes.
  13. Dave B
    Oh, just wait....
  14. 71gold
    found an issue, don't know yet if it was the problem. the noisy side had an...outer race...spinning in the hub. I replaced the rotor, bearings and seal and will road test it tomorrow...:drive:
  15. scooper77515
    Did you use the bearings that came with the R&C Kit? Instructions say they are a different size than the standard MII bearings, and a bearing failure WILL occur.
