Soi, i'm thinking of throwing my Maverick up on Ebay...
Discussion in 'General Maverick/Comet' started by Streamliner, Jun 9, 2013.
  1. Streamliner
    Streamliner Member
    My girl and i are in the process of buying a home in Florida and relocating from NY and the money from the car would help with moving expenses and other things....Problem is i have no idea what it's worth and no clue what to set the reserve at.....I know there's a limited market for it considering the way i built it.....I have a number in my head but i could be way off....I'd be curious what you guys would set the reserve at if it were you
  2. mercgt73
    mercgt73 Member
    If my first child was born as of today... I would even include a months worth of diapers.
  3. Mavman72
    Minimum of 25K for that beast...C'mon its basically a street legal road course racer.
    How could you ask less???
  4. mrskydog
    Muskegon MI
    Wow what a Awsome Car!! Very well done. I have no idea what you have in it, but to the right person, I would say a reserve of 25,000 dollars also. Its one of a kind.....sooooo Cool!!
    I need to grab a rag I am Drooling all over the place. :thumbs2:
  5. Streamliner
    Streamliner Member
    [FONT=&quot]1972 Ford Maverick Trans-Am Replica[/FONT]
    [FONT=&quot]I built this as a “what if” Shelby American were still churning out road race cars in 1972[/FONT]
    [FONT=&quot] Started with a rust free [/FONT][FONT=&quot]California[/FONT][FONT=&quot] car….[/FONT]
    [FONT=&quot]The goal was to make it as light as possible and make it street legal and although it hasn’t been raced or autocrossed, it is built to do so[/FONT]
    [FONT=&quot]289 CI…[/FONT]
    [FONT=&quot]Lopey cam…..Unknown specs[/FONT]
    [FONT=&quot]10:5-1 cr…[/FONT]
    [FONT=&quot]AFR 1402 aluminum heads….[/FONT]
    [FONT=&quot]1:6 roller rockers[/FONT]
    [FONT=&quot]Full length headers….[/FONT]
    [FONT=&quot]Edelbrock intake…[/FONT]
    [FONT=&quot]700 cfm Holley dp carb….[/FONT]
    [FONT=&quot]Remote oversized racing oil filter….[/FONT]
    [FONT=&quot]Fluidyne heavy duty oil coil with -12 an hoses…[/FONT]
    [FONT=&quot]Custom carbon fiber air box which picks up cold air from the base of the windshield[/FONT]
    [FONT=&quot]Aluminum radiator Custom made aluminum with 2 piece quick-connect shroud[/FONT]
    [FONT=&quot]HEI distributor[/FONT]
    [FONT=&quot]Completely welded in sub-frame connectors[/FONT]
    [FONT=&quot]Drive shaft loop[/FONT]
    [FONT=&quot]Custom made spring tower braces[/FONT]
    [FONT=&quot]Battery[/FONT][FONT=&quot] relocated to trunk[/FONT]
    [FONT=&quot]Custom made heim jointed adjustable struts[/FONT]
    [FONT=&quot]New upper and lower a-arms boxed for strength[/FONT]
    [FONT=&quot]Pro Shocks Adjustable[/FONT]
    [FONT=&quot]Upper a-arm mount points lowered 1” for improved geometry[/FONT]
    [FONT=&quot]1-1/16” Mustang sway bar adapted[/FONT]
    [FONT=&quot]1” removed from front coils[/FONT]
    [FONT=&quot]4 wheel disc brakes with cooling ducts[/FONT]
    [FONT=&quot]American Racing 2 piece Torque Thrust D wheels[/FONT]
    [FONT=&quot]265/50/15 tires on all 4 corners[/FONT]
    [FONT=&quot]T-5 transmission with Pro 5.0 shifter and custom made relocating handle[/FONT]
    [FONT=&quot]New clutch and flywheel with CNC reverse swing hydraulic pedal set up[/FONT]
    [FONT=&quot]6 pt. roll cage…Kirkey race seats[/FONT]
    [FONT=&quot]Autometer Gauges….Battery shut off switch[/FONT]
    [FONT=&quot]2”x 3” frame connectors…5 pt. Cam-loc racing harness[/FONT]
    [FONT=&quot]Plexiglass rear and quarter windows[/FONT]
    [FONT=&quot]Straight through 2 ½” {no mufflers} with X pipe[/FONT]
    [FONT=&quot]8” Ford rear with brand new Traction-Lok and 3:80 gears[/FONT]
    [FONT=&quot]Custom made [/FONT][FONT=&quot]Watts[/FONT][FONT=&quot] link
    [/FONT] [FONT=&quot]RCI fuel cell-19 Gallons[/FONT]
    [FONT=&quot]On-board fire system[/FONT]
    [FONT=&quot]Electric fuel pump[/FONT]
    [FONT=&quot]Cougar LED tail lights[/FONT]
    [FONT=&quot]Front fenders widened 1”[/FONT]
    [FONT=&quot]All side marker lights filled in[/FONT]
    [FONT=&quot]Grabber hood louvered and framework extensively drilled for lightening[/FONT]
    [FONT=&quot]Deck lid frame drilled for lightening[/FONT]
    [FONT=&quot]Louvered rear lower valance[/FONT]
    [FONT=&quot]This is a sole purpose race car that is streetable….[/FONT]
    [FONT=&quot]There is no insulating, sound deadening, heater, a/c, stereo or any thing else that doesn’t either make it go faster or stop better…..[/FONT]
  6. Craig Selvey
    I would say at least $20,000.
  7. 71gold
    way too much info. for an Ebay ad...
    "it hasn’t been raced or autocrossed"...not a plus...(no speed/times or handling info).
    $8500
    JMO
  8. maverickoutlaw
    maverickoutlaw Member
    St Marks, Fl
    1973 maverick
    $20,000 easy. Where in Florida are you moving to?
  9. rthomas771
    Maybe $12,500
    You mention frame connectors twice
  10. Streamliner
    Streamliner Member
    Palm Coast, near Daytona and St. Augustine
  11. Streamliner
    Streamliner Member
    I'm honest to a fault
  12. car-nut
    car-nut Glenn
    conn.
    I like it, the more detailed the ad the better. I would agree with others that around $20k would be a good place to set a reserve. I am sure you have more than that in there. Awesome car for sure, if I was in the market for that type of car I would find it very appealing.
    Good luck.
  13. scooper77515
    Not street legal in most states. I see no mufflers at all on this thing.
    I bet it sounds pretty nice, though!
  14. car-nut
    car-nut Glenn
    conn.
    What makes you think it doesn't have mufflers? I haven't seen any under carriage shots of the car posted?
  15. rthomas771
    Scooper can read :clap:
