heater control valve stuck
Discussion in 'Technical' started by mashori, Feb 19, 2009.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    My heater won't work on my 71 mav, A/C works great and all the other functions are fine on the control panel. I checked my heater control valve and noticed it was kinda stuck so I turned on the heater and manually pushed down the lever on the control valve and the heater worked great.
    Do I need to change the control valve? Is there a cheaper one than this $70 piece?
    Also, is it hard to change? Because it looks like I'd have to drain the coolant.
  2. Mavman72
    Pinch off the hoses then remove the old one.(minimal coolant loss that way)post an add on the forum...betcha someone has a good one to sell.Or go junk yarding.Should be able to find one in any ford/lincoln/merc with A/C of the era,just gotta hope you find a good one.
  3. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
  4. 71gold
    what you need to know is what valve it is...norm open/closed... these valves work both ways.
    my valve will close when i start the car...when i turn the heater on, it opens...:yup:
    you are on the right track to find one. i have a black plastic one on my Mav.
    ...Frank...
  5. 71gold
  6. 71gold
    you may want to flush the heater core while you're at it. just take both heater hoses off at the engine. run water through one hose and then the other. do this untill the water is clear. change the valve and all you have lost is the coolant in the heater core.
    ...:thumbs2:...
  7. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    nice! that sounds simple. got it . . . and sweet idea about pinching the hoses, so simple but saves me a lot of time.
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Could I purchase this one instead? I see it on the parts list of the 1976 cars. Does it have the vacuum regulator on it as well? This is thing is like $12! :yup:
  9. 71gold
    i would say...YES...make sure the valve is closed w/vac. on. (5/8"x5/8")
    ...:Handshake...
  10. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Oh good! my local Kragen in santa monica has it so I'll pick it up.
  11. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I bought a NOS Maverick valve off of eBay for less than $25. They are out there, just have to look around...
  12. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    I am running one of those. There are two vacum lines running through your firewall if you trace them you will find that they both go to a T and the upper one has a cutoff valve inline "water valve vacuum switch"(you can see it on the front of your heater box ) all it does is is allows the valve to open more when the heater is in certain positions (defrost compared to floor whatever) but they both come from the same vacuum scource.[​IMG]
  13. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
