Rack and Pinion Update
Discussion in 'General Maverick/Comet' started by CornedBeef4.6L, Jan 26, 2007.
  1. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    As some of you know I am working on a Rack and pinion swap.
    After eliminating 3 racks as follows
    Manual rack From 2003 Saturn Ion( It was to long and honestly had a poor gear ratio 4.5 turns)) It did have the easiest Mounting capabilites. I feel this could still work with more effort than I am willing to go through.
    Dodge Omni (rack Didn't center well) and well it came from dodge:rolleyes:
    Toyota Pick up manual rack early 90's (poor angle on the steering coupler)
    It has come down to the tempo Rack. The inner rod ends can be cut and rethreaded the easiest. Has all the right angles but I dont like the mounting configuration. Makes for a much harder centerline to be attained for proper geometry.
    This saga to be continued.......:bouncy:
  2. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    Lance, check out some of the GM front wheel drive, 80's models. They have center steer, makes for alot less chance of bumpsteer problems.
  3. Shinysideup
    Shinysideup Chillin the most
    town
    car
    bumpsteer is caused by the angles from the rack to the tie rod ends on the vertical plane. as the car rises and falls the distance from the rack to the tires changes and causes dangerous issues of toe in/out. bottom line is have the rack in line with the tie rod as close as possible.
    those that lower their cars excessively will notice this as the rod ends are pointed upward badly.
  4. scooper77515
    keep it up, I am interested in a swap without having to fork out $1500-$2000.
  5. RabidCustoms
    no comment:cool: .........(oops, this constitutes as a comment:D )
  6. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    2 more posts:bananamantill you leave
  7. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    Sorry to bring this back up, but ever think about a ranger/bseries manual rack, 93-...? That's what I'm thinking about, but haven't done any camparing yet
  8. tweet66
    tweet66 where am I?
    Pennsauken, NJ
    Look at Nissan 200SX racks as well. They're rear steer, 2.5 turns lock to lock, power, and fairly easy to mount. I used one when I converted my 64 Falcon to R&P. So far so good:thumbs2:
  9. Thack
    Thack vision advicator
    Moreno Valley Ca
    Look at daewoo I rack..............:D
