Hey Guys, I'm new to the forum and hoping someone can help me out. I've got a 1977 4DR, V-6, Maverick with a busted instrument cluster. The interior's tan. Any ideas on where I can get a good deal on a used/reman unit? Also, does any one know what years are compatible with my car? I heard somewhere that if you don't use one from the right year it won't work. If anyone out there can help, I'd really appreciate it. Thanks, Rusty
might get more attention in the wanted section , and more than likey you have a inline six not a v6...just trying to help
A '75 and up cluster should be a direct replacement in your car. '74 if you like the old style gauges better. What's wrong with your current cluster?
That sounds typical of the later model years when they started using crappier plastics. I had the same problem. On a different note, the wiring plug is different from '75-'77 when they eliminated the points ignition. I may have a spare one lying around that I don't need.
The same thing happened to the cluster in my 76. Luckily I have two more clusters, one 75 model and a 72 model.
