Instrument Cluster?
Discussion in 'Parts Interchange' started by MikeG747, Dec 4, 2005.
  1. MikeG747
    MikeG747 Member
    Arkansas
    Has anyone ever put an older Cluster in a 77. The 77 reads 100 MPH. Was wanting to put a 73 model in that is available that reads 120 MPH. I was wondering if the wiring is the same & if the Speedometer would read correctly etc.. My son's 77 needs a new cluster & we can't locate a 77 cluster.
    Thanks, Mike:)
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I don't know your answer, but if you do a search, I saw that topic being discussed in length. Was in the last week or two.
    I like the looks of the earlier one myself.
    I think 75 was the last year for it.
    Good luck
    Dave
  3. Mavaholic
    The speedometers are interchangeable.
  4. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    Yep what Mavaholic said...
  5. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    There is a difference with the early and late model printed curcuit sheet that mounts on the back of the cluster. I think there is an extra curcuit added for late model economy idiot light. If idiot lights dont matter, then everything should interchange. When changing from 100 MPH to 120 MPH, don't forget to get your speedo calibrated.
    Ken
  6. MikeG747
    MikeG747 Member
    Arkansas
    Where do you go to get them calibrated?
    Thanks, Mike:)
  7. Mavaholic
    Dosent need calibration. Its self contained.
  8. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    Dennis,
    You don't need to calibrate (change the plastic trans. gear)when you change the speedo from 100 MPH to 120 MPH????????
    Ken
  9. Jamie Miles
    Don't know the exact years, but a cluster from a '71 Maverick would not plug into my '74 Maverick's wireing harness. The '74 plug was smaller then the 72's plug. You will probably have to take the clusters apart and and put the early guages in your '77 cluster. As far as the idiot lights, I "think" you should be able to swap the plastic film that clips into the back. Hard to explain without showing what I'm talking about...
    As far as I've seen, '74 was the last year of the 120 mph speedometers.
  10. Mavaholic
    Nope. The difference is in the speedometer its self. They just have stiffer springs in the 120 movement. Its easy enough to verify. Just take a drill and hook it up to each one and run the drill full speed. It will read the same mph on both.
  11. Mercurycruizers
    Venetia, PA
    There is a difference with the plug. I tried to put a 74 cluster in my 73 & the plug wouldn't fit. I ended up destroying the 74 cluster, trying to cut the hole big enough. Just my 2 cents....
  12. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    Thanks Dennis for the correction. Ya learn something new everyday.
    Ken
  13. Craig Selvey
    I went out and compared the ones I have. The early style housing has a bigger plug than the later style housings. While the "insides" may be interchangeable....the white plastic housing as well as the circuit strip is different and will not interchange.
  14. ratio411
    ratio411 Member
    Pensacola
    My 75 has the 120.
    It also has the metal look center on the pods.
    My car was a "non-cat" 75, however some 75s had cats.
    I think that is the difference.
    If your car had cats, you had the later gauges...
    All black
    100 mph
    and most significantly, "unleaded fuel" label on the gauges.
    Dave
  15. sierra grabber
    sierra grabber Certifiable
    northern nevada
    well if you dont care about a little splicing on the wires for the back of the cluster you could just splice the plug on to the wires in your dash. might have to verify they are for the same things.:huh:
