Late model 5.0 in a maverick
Discussion in 'Technical' started by 76 Mav, Sep 25, 2002.
  1. 76 Mav
    76 Mav Reformed Camaro junkie
    Cobb County Ga.
    76 Mav , 70 Galaxie ,04 F350,03 Mustang,03 F150
    Ive got a turbo 5.0 out of a lincon mark VIII that i want to drop in my maverick.
    Does anyone know of an aftermarket wiring harness i can use to make the installation a little easier ?
  2. Charlie
    Charlie maverick.to/grabber
    Indianapolis, IN
    1970 Ford Maverick Grabber (Modified)
    How about a little more application info, sounds like a strange setup. Mark VIIIs had 4.6L engines, Ford never had a factory turbo 5.0L. Does it still have a Ford-style EFI system on it?
  3. 76 Mav
    Cobb County Ga.
    oops
    Sorry i have 5.0 of the brain lol ... its a totally stock 4.6 fresh from the salvage yard ... Painless wiring sells harnesses for a 5.0 but i cant seem to find one for a 4.6 ...
  4. EFIMAV
    EFIMAV Member
    Davenport Iowa
    I'm going to guess it will not fit unless you make major modifications to the front end. The 4.6 is much wider than a 5.0! Basically, if a 4.6 will fit so will a 460. At that point, go with the big block! Remember, on the 4.6 the cams are on top of the heads. A totally different creature than the old push rod engine!
  5. 76 Mav
    Cobb County Ga.
    Thanks ...
    Yeah i know its going to be a job ... But i think im going to go with a mustang II front end... Itll be snug but not too bad...
    I like the 4.6 and with the turbo in a maverick its gonna be a guick little car ... I dont plan on racing ( Too much lol ) and the thought of the trouble free performance plus the deal i got on the turbo 4.6 i really couldnt pass it up ...
    Oh by the way i talked to Painless a little while ago and they said they can do a partially custom harness that plugs right into the lincon " Brain"
    Sounded fairly simple but you know how that goes :)
  6. Charlie
    Indianapolis, IN
    Ok, well there has never been a 4.6L turbo either (OEM), so what exactly is the deal with this thing? Is it a custom job?
  7. 76 Mav
    Cobb County Ga.
    Yeah
    Its a custom job ... But the more i look into it i think im going to hold off on the turbo for now, its a little over my head and the cost is just too much .... Im looking into superchargers ... The instalation seems to be a little easier and its a little bit cheaper...
    Im still going with the 4.6... I got a deal on the motor and i really couldnt pass it up
