Regular bucket seats vs LDO???
Discussion in 'Technical' started by bigal3000, Aug 24, 2004.
  1. bigal3000
    bigal3000 Member
    Vancouver, Washington
    1973 Grabber
    I'm getting ready to install high back buckets in my
    Grabber, but after test fitting them today they're going
    to be too high off the floor.
    There's about 2" of bracket between the actual sliders
    and where they mount to the floor. I've been thinking
    about taking off the bracket and fabricating a
    replacement out of plate that would only be about
    1/4" high.
    Then it occured to me that somewhere I had seen a
    picture of an LDO seat bracket and that it's already a
    flat bar instead of a tall gusseted bracket like I have.
    Does anyone know the facts on this? Could I get use
    set of LDO brackets and save myself a lot of fabrication?
  2. Sam M.
    Sam M. Just a nobody
    Southern NJ
    I wasn't aware that there were any differences in brackets other than those for the inboard passenger side on cars equipped with a cat. I'd be interested to hear if anyone can shed some light on this.
    Sam
  3. Maverick Man
    California
    well i did something with the stock LDO brackets.. may be you can compare them to the install pics i did awhile back.
    you can kinda tell what they look like in the pictures even though my fabed up adapter is bolted to it.
    http://www.maverickman.com/SeatInstall.html?1059814159453
    good luck
  4. bigal3000
    bigal3000 Member
    1973 Grabber
    Okay, this is perfect, you're just the guy to answer my
    questions!
    I have attached a cropped photo from your web site
    that shows the LDO seat bracket with the flat bar
    adapters you've attached to mount the Cobras.
    In the picture I have placed two arrows pointing to a
    tan seat bracket. Other than the black plate that you've
    attached, is that what a stock LDO bucket bracket
    looks like?
    Other than the spacers that go under it, it looks like it
    sits nearly as flat as you can get to the floor. That's
    what I need to achieve.
    I look forward to your answer. :)
  5. Maverick Man
    California
    yes.. but remember between the bracket i bulit and the tan piece there is the metal slider.
  6. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I am using LDO brackets on my standard bucket seats and they definititly sit lower than stock ...
  7. Maverick Man
    California
    yeah they do sit low on other seats...
    as you can see in this pictures my seats are on the floor! they way i like it!
  8. bigal3000
    bigal3000 Member
    1973 Grabber
    YAHOO! That's just what I need! :bananaman
    Okay, anybody out there have 2 sets of LDO seat
    brackets for sale (driver's side and passenger's
    side)? How about 1 set?
    Thanks!
  9. Maverick Man
    California
    good luck in finding those.. kinda hard to find i would say.
    the last board yard i went too... non pic a part they wanted to sell the whole seat. :(
  10. dmhines
    Cumming, GA
    Can I see the picture of your tracks? Maybe we could do an even trade. I would rather have my seats higher off the floor ...
  11. bigal3000
    bigal3000 Member
    1973 Grabber
    Absolutely! I will go over to the shop today and
    get some pics. I have two sets from which you
    can pick the best pair. (y)
  12. dmhines
    Cumming, GA
    Cool ... I'll get some pictures of my buckets mounted in the car so you can see how low the sit .... Dan
  13. dmhines
    Cumming, GA
    Here are my LDO tracks ... basically resting on the floor .....
  14. bigal3000
    bigal3000 Member
    1973 Grabber
    They're absolutely perfect for what I'm trying to
    accomplish with my car's seats!
    Here's a couple of shots of the type that I have.
    I have two pairs that are in nice shape and I look forward
    to making a trade with you. I hope they are what you're
    looking for. (The one here that's rusty is just to show the
    type off of the seat. The ones I would trade you are much
    nicer.) :)
  15. dmhines
    Cumming, GA
    I am not sure if I have a mismatch of tracks or not ... two of my tracks are similar to that ... I put those towards the transmission tunnel. The other two tracks are flat .. I put them near the doors. This setup allows the seats to sit low and level since the mount points near the hump are lower ...
    I would like to trade if you want to ...
    Dan Hines
    1960 Pilgrim Road
    Cumming, GA 30040
    I have some car shows coming up so if you could ship yours first, I'll swap them and ship mine back to you ... It sounds like you are still finishing your car up ....
    THanks .. Here is another pic showing how much head and leg room under the steering wheel you have with my setup ...
    http://mmb.maverick.to/attachment.php?attachmentid=5876
