#1 |
Re Member
Vehicle(s): '72 GrabberiTrader: 4 (100%)
Boy oh boy! Another spring cutting thread...
Yes, I know there are a ton of them and I apologize. The problem is that the pics in some of the older threads have disappeared. I really need to see some pics of ride heights based on number of coils cut, front end weight(big bumper or small, V8 or I6, aluminum or iron heads, fiberglass parts or steel), and type of spring used(6 banger, V8, aftermarket etc...). I think 1 1/2 coils is what I will end up cutting off, but if you guys could post up pics of your rides again, I would be very grateful.
![]() AC |
| Sponsored Links |
#2 |
Original owner
Vehicle(s): Stallion, 72 Grabber, Sprint, 77 4dr MaverickiTrader: 11 (100%)
Here is the deal,,, each car has its own history. You cut stock coils, what you see is what you get. I dont think there is a manual on this subject. Pics of cars with cut coils will be of little help. Too many variables here, engine, wheels, wear, age, rear suspension, updates, etc. My advice is to cut one coil at a time and see where you are at. I personally cut 1.5 coils off original coils. Dropped it about 2"
Dan |
#3 |
Die-Hard Ford Guy!
Vehicle(s): 72 2-door Maverick 308/C-4iTrader: 2 (100%)
Mustangs and Fords November 2004 issue has an article on Lowering vehicles. Pretty good article. It's the one with the Blue 600 horsepower Rustang on the front. Preston
__________________
There are two kinds of drivers; those who make dust & those who eat it......Which kind are you? www.myspace.com/maverick7285 |
#7 |
Re Member
Thanks for the input guys. I think Ill start with 1 coil. My springs seem pretty stout, as the car has always had its nose up in the air. If it takes it down too much then chances are I needed new springs anyways right?
AC |
#8 |
Banned
Keep in mind; I replaced my rear springs wwith 4-leaf heavy duty. if your stock springs are already saggging, then dropping the front won't seem so drastic...it will even it out more...be low all the way around. My car has a "rake" now...
#9 |
Indiana State Rep - MCCI
Let's see a picture TL...I want to see the new stance with all your "spring" work.
__________________
Craig's Maverick Corral: http://www.maverickcorral.com To email me DIRECTLY, do NOT click on my name to the left and choose an option, instead, email me DIRECTLY at:
Interested in this thread? Receive email updates and post your own response by registering today, it's free! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Another spring cutting??? | rx7351w | Technical | 34 | 2004-10-28 07:46 |
| coil spring cutting - does it need to be removed? | acceleron | Technical | 4 | 2004-04-30 20:02 |
