mav madness
Discussion in 'Technical' started by teslajc, Nov 15, 2004.
  1. teslajc
    teslajc 75 mav
    strathroy ontario canada
    maverick
    hey i am having a problem starting my car it is a 75 250 6 cyl i have changed the starter the alternator checked the battery changed the ignition switch and still it is not starting i also changed the selenoid.now when i turn the key the selenoid just clicks i hooked up a booster cable and the damn thing got hot and it almost started i tried it again and the booster cables caught on fire HELP i drive my mav everyday and this is gettting to me
  2. FoMoDave
    FoMoDave Maverick Owner
    Cumming Ga.
    1973 Maverick 302 c-4,1971 Maverick 6cyl
    How did you check batt.? It may still be bad but show full charge.
  3. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    How are the cables from the battery to the starter? also check connections, and ground cables.
  4. teslajc
    teslajc 75 mav
    maverick
    checked
    alll cables are new possitive negitve and starter to selenoid are new as well also changed the selenoid
  5. Earl Branham
    Lugoff, SC
    Sounds like the starter, or the solenoid switch. Start with the switch, as it is the least expensive. The clicking makes me think it is the switch. Good luck!
  6. teslajc
    teslajc 75 mav
    maverick
    changed
    changed the selenoid and the starter new cables everything this is really annoying
  7. FoMoDave
    Cumming Ga.
    Did you try a new batt.? May have a direct short inside.Sounds like you have replaced everything but the wiring itself.If everything is new including batt. ,must be the wiring somewhere.??? Anyone else have an idea?
  8. Earl Branham
    Lugoff, SC
    Just because the parts are new, doesn't mean they are good. If you got them from AutoZone or Advance, I would check them out again. I went through 3 or 4 solenoids before I got a good one....at NAPA.
  9. Mavaholic
    Alot of this was already covered on your other thread on the same subject. It would help if you could keep one thread per problem. Geeze, I sound like a message board nazi.
