Pics of some rims
Discussion in 'General Maverick/Comet' started by Mav Rick, Jan 19, 2005.
  1. Mav Rick
    Mav Rick Member
    St. Petersburg, FL
    1971 Grabber
    I am on a quest to find the perfect set of rims for my 71 Grabber. I am leaning towards a set of 15x8 (rear) and 15x7 (front) Torq Thrust II's.
    My first question is if anyone has these or knows someone who has them on a Maverick, would you be able to post a pic or two of them on here?
    My second question is, since I havent fully made up my mind, if you wouldnt mind having a quick show (off) and tell, I would really like to see some pics of the rims you all have on your Mavs.
    Thanks!
  2. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    If you can please posts some pics of your car, What kind of look are you going for with your Maverick? Stock,Hot Rod,Cruiser?
  3. Kilg0re
    Kilg0re Doh!
    Lees Summit, Missouri
    I say just cut a lot of stuff and put 20's on :p j/k Do need pics of your car to see what would look best...
  4. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    Go to the home page and click on photo gallery....more pics of cars with different wheels than you can shake a stick at.
  5. Mav Rick
    Mav Rick Member
    St. Petersburg, FL
    1971 Grabber
    When finished, I kinda want the street racer/hot rod look. I just got the car a few weeks ago, and want do do the "needed" things first, but for looks, Im going to need the rims, ya know?!
    I will take a look at the pics, thanks for the info.
    --Rick
    I added some "custom" rims to the pic. Give ya a little laugh.
  6. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Ya know I think a set of Crager Keystone classics would look good on that and the price is reasonable.
  7. Mav Rick
    Mav Rick Member
    St. Petersburg, FL
    1971 Grabber
    Good choice! I was looking at a couple of Cragar's... that was one of them.
    While we are at it, does anyone want to explain what back spacing is on wheels. I think I may need to know this before going in and getting something.
    Thanks!
  8. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    From what I gather, backspacing is the distance from the inside bead of the wheel to the wheel mounting surface. Generaly on these cars, I think BS should be 4", but correct me if I'm wrong and I'll remove this post to avoid confusion
    Shaun
  9. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i think,:hmmm: i have 17x7 all the way around that way i can rotate the tires
  10. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    depends on rim size.
  11. Mav Rick
    Mav Rick Member
    St. Petersburg, FL
    1971 Grabber
    Yup. im still confused about the backspacing thing.
    I am just concerned about rubbing issues. What would be the widest tire I could get on the back and front? I was thinking 245/70/15 (rear) and 235/70/15 (front). I didnt even think about the rotating of the tires, thanks for the input!
  12. Mav Rick
    Mav Rick Member
    St. Petersburg, FL
    1971 Grabber
    Does anyone know what size tires and rims Shawn Simpson has on his Maverick? or does anyone know how to get ahold of him to ask?
    Thanks!
  13. fan2488
    fan2488 Member
    spring,TX
    double checked mine today i have 17 x 8, 235/45/17, all the way around.
  14. skin
    skin Registered User
    Northeast Ohio
    '73 357ci Grabber
    I think the Keystones are the rim of choice.
  15. BIGbully
    BIGbully Maverick Maniac
    Omaha, Ne
    Foosed on Photoshop
    I like the Foose Lusso,(y) but the offsets would require a spacer.
    I hope the attachment works, my computer is freakin' out lately.
