Grabber Hood Rust Repair (By an Amateur!)
Discussion in 'Cosmetic' started by Erick-Mav, Feb 28, 2005.
  1. Erick-Mav
    Erick-Mav Maverick Punk
    Oceanside, CA
    71 Grabber-Factory V8 w/3spd, 72 Maverick-351 Procharged for Strip, 71 Comet GT-331/4spd
    I fixed the rust under on the lip of my hood by cutting a part from a regular Maverick hood and welding it on. I'm happy with it.
  2. rayzorsharp
    That's a helluva good looking job there. Ever need a job in a body shop come see me. (y)
  3. Mavaholic
    I think you need to upgrade your ameteur status.
  4. 71gold
    great job...:yup: (y) ...frank...
  5. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Great Job! I think you found a new profession ... Grabber Hood Repair ... I'm sure you'll have people on this board lining up! (y)
  6. stmanser
    Davenport, Iowa
    im first to sign up......
    fix my hood.....my rust is a little more extensive.....but what did you use to do the repair??
  7. Jean Doll
    Palmerton, PA
    Great job Erick. That sure does'nt look like an ameteur to me. Well done.(y)
  8. Rando76
    Rando76 Member
    Claremore, OK
    SWEET :eek:
  9. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I am highly impressed. That looks awesome.
    Dan
  10. Erick-Mav
    Oceanside, CA
    Thanks guys. I was pretty excited myself because I was dreading doing the repair for a while and was even planning on getting a fiberglass hood for a while.
    I cut out a piece from a regular hood and luckily it fit real good. I accidentally cut through the top of the hood in one area. The prep work was very time-consuming. I had to grind out rust, paint on rust converter on the surfaces, etch-prime and glue the piece down. The welding was slow, got it all tacked up then welded and grinded. The grinding was the hardest part. PITA. The whole job took me about 24 work hours. I thank the body guy that encouraged me to fix it and this board for keeping me motivated.
    By the way, I finished the body work on my Grabber and the car is now ready for paint. Body work was a pain...just kept finding small dings and mild rust to fix. I only used 2 small cans of mud and I'm now pretty good at fixing the dings by hammering and adding a small amount of body filler. I'll post pictures after its done.
