Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical
Notices
Reply
Thread Tools Display Modes
Old 2005-03-24, 10:40   #1
one3rd
Novice
common problems
I am looking into purchasing a 74 maverick today that has 53,000 original miles on it. I just wanted to see what the common problems these cars have and if i keep the normal check ups and maintenance on it, if this car will last another 100,000. Thanks for your help.
one3rd is offline   Reply With Quote
Sponsored Links
Old 2005-03-24, 11:29   #2
Jean Doll
Maverick Restoration Tech
Jean Doll's Avatar
Vehicle(s): 1977 Maverick 2 door with a 302.
Images: 4
The most common problem you will face is rust. As much as we love these cars, they tend to be rust buckets. Of coarse, that depends on where the car has spent it's life. Southern cars are less likely to be as rusty as Northern cars. Make sure you check the floorboards, torque boxes,front and rear frame rails, inner fenders, inner quarters, trunk floor and the front cowl panels for any rust problems. Rust in the cowl panels is not easy to see, but if there is any indication of water leaks or signs of standing water inside the car under the heater box or on the drivers side floor pan, then the cowl panels may be rusted through. Also check around the front and rear windshields for rust. Water can seep into the car from those locations too. Give the outside of the car a good looking over and check for signs of old bodywork in the quarters, lower doors and lower fenders. Those are other well known rust spots.
Jean Doll is offline   Reply With Quote
Old 2005-03-24, 12:06   #3
74merc
computer nerd
74merc's Avatar
Vehicle(s): 1974 Comet
The front windsheild support on the bottom has rusted out on two of my cars... it leaks, drains down the firewall, drips on the radio, etc, looks like a cowl leak...
__________________
74 Mercury Comet
302, Performer 289 intake, Autolite 4100, Hooker Super Comps
AOD
3:1
http://members.tripod.com/red74merc
74merc is offline   Reply With Quote
Old 2005-03-24, 12:32   #4
littleredtoy
Seth
littleredtoy's Avatar
Vehicle(s): '74 Comet GT
Images: 27
The biggest common problem is finding replacement parts.
They make many or most of the mechanical parts, but
body panels, trim pieces are tougher to find everyday.
Seth
littleredtoy is offline   Reply With Quote
Old 2005-03-24, 16:44   #5
igo1090
Member
igo1090's Avatar
Vehicle(s): 75 maverick, 93 tbird tube car
if the engine still has the oem timing set in it, the plastic teeth on the top gear always wear away and retard the cam timing until it finally skips a tooth and stops you. can be a problem over 80,000 miles, but can be easily taken care of.
__________________
dave shea
s/st 1818, h/r 1564, s/p 1018
igo1090 is offline   Reply With Quote
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
carburetor problems duster70 Technical 7 2006-09-06 17:31
Car problems JeffScoggins General Maverick/Comet 19 2005-03-04 14:50
Fuel Problems Solved!!! Country Mav General Maverick/Comet 7 2004-10-11 23:47
What is the most common you get Wes General Maverick/Comet 28 2004-07-04 10:01
cooling problems? david targhetta Technical 14 2003-05-08 10:23
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
