Break lights/turn signal switch Man, what gives!!!
Discussion in 'Technical' started by mark_b, Nov 26, 2002.
  1. mark_b
    mark_b Member
    western PA.
    73 all original 302 2d red blk int. 72,302.2dr. green and 71 200ci. 2d green
    Can a bad turn signal switch cause one or both break lights to fail?
    Current situatation:
    1. Had no break lights.
    2. had decent but weak left turn signal, Yet no right turn sig.
    3. Checked all grounds and bulbs.
    4. replaced break light switch on break petal.
    5. Had both break lights working!
    6. strangly enough, and with several tests...right break light
    all the sudden quit working.
    7. last but not least, along with the right break light the turn
    signals don't work at all!
    Break light........I checked for power to the right break light and there was none. I replaced the socket that the bulb goes in and still no power to the bulb. The wire just isn't getting juice!
    Could the turn signal switch cause all this?
    Where can I find a new one? what years are interchangeable? (Mine is a 71)
    Thanks for any help!!!!!!! Big time! Mark
  2. bmcdaniel
    Yes. The power from the brake light switch at the brake pedal goes through the turn signal switch before heading back to the tail lights. That way one side will blink if the turn signal is on and the brakes are applied at the same time. Good luck!
  3. mark_b
    mark_b Member
    western PA.
    Where can I get replacement parts for the turn signal switch?
    Mark
  4. Earl Branham
    Lugoff, SC
    Mark; AutoKrafters has them. Go to autokrafters.com.
    Earl
  5. mark_b
    mark_b Member
    western PA.
    Thanks Earl!
  6. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    try junk yards... i paid 10 bucks for my switch... up to 1972 should work for your car. ask on the "parts wanted" section of this board. somebody must have one they want to unload rather than just throw it out. good luck.
