Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical
Notices
Reply
Thread Tools Display Modes
Old 2002-11-26, 13:43   #1
BILL BARR
Novice
Disc brake conversion
I looking to convert to disc brakes on the front of a 71 Maverick. Does anyone know who makes a conversion kit?? Can I use a kit for another model (mustang, ect)?
BILL BARR is offline   Reply With Quote
Sponsored Links
Old 2002-11-26, 14:43   #2
mark_b
Member
mark_b's Avatar
Vehicle(s): 73 all original 302 2d red blk int. 72,302.2dr. green and 71 200ci. 2d green
Bill, the most economical way is to go to a junk yard and get these following parts of a 70's manual disc break Ford Granada.
1.Front disc break spindles
2. rotors if in good shape.
3. The disc break proportion valve
get new calipers.
get a new master cylinder.
Get new wheel bearings and rotors
Get new break lines (the flexable ones).
Search the Technical forum where there is more detailed info on this fairly easy swap.
It can be done in an afternoon.
I think the cost for mine was about 300 bucks..thats with brand new rotors.
There is a full conversion kit in auto krafters parts book for about 945 bucks.
mark_b is offline   Reply With Quote
Old 2002-11-27, 11:01   #3
BILL BARR
Novice
Thanks Mark.
I'm going to check with Wilwood and Areospace also. The car is a 10 second drag car so I want to upgrade from EOM rotors and calipers. The Granada spindle helps a lot.
Old 2002-11-27, 23:15   #4
scott
Member
Vehicle(s): 1970...302 c4 hookers dynamax (for now)
945 bucks??????? i am in the wrong business...
__________________
purrin like a kitten...
scott is offline   Reply With Quote
Old 2002-11-29, 13:16   #5
Maverick Man
The Original Maverick Man
Maverick Man's Avatar
Vehicle(s): Two 1973 LDO Mavericks (one 4 Drag one 4 driving like Mad on the roads :) ) also have a 75 6cyl Stock! Ok, well sort of Stock :P
Images: 19
BILL BARR what part number are you going to be using for wilwood? And when you get them will you be using the Granada spindle with that appication?
__________________
Carbon Fiber Grabber Hoods, OE Flat Hoods and Cowl Hoods are IN STOCK NOW and Spoilers are Out Of Stock
Maverick Man is offline   Reply With Quote
Old 2002-11-29, 14:21   #6
BILL BARR
Novice
Mav Man,
I haven't got a hold of Wilwood (holidays), but they don't list a maverick application on their web site (who does?). I did get a hold of a company called Stainless Steel Brake that does make a conversion kit using your own Maverick spindles. The guy said they work as long as you have 5 bolt wheels. The kit is about $950. We are not ready to start this project yet so I'm going to do some more research.
Old 2002-11-29, 19:59   #7
BOSSMAVERICK
Member
Vehicle(s): 1972 Maverick Grabber
Try this use Wilwood kit for a 69 Mustang. the Maverick and 69 Mustang use drum brake spindle. The kit cost is $639.99$http://www.martelbros.com/cgi-bin/st...od/wilwood.htm Maverick
__________________
BOSSMAVERICK is offline   Reply With Quote
Old 2002-11-29, 20:04   #8
BOSSMAVERICK
Member
Try this use Wilwood kit for a 69 Mustang. the Maverick and 69 Mustang use drum brake spindle. http://www.martelbros.com/cgi-bin/st...od/wilwood.htm Maverick
__________________
Old 2002-11-30, 03:28   #9
Maverick Man
Images: 19
Yes I have seen the Stainless Steel Brake kit that you talk about... my buddy put that on his mustang with the Granada spindels.... however I wanted to go at least a over kill of 12-1/2 inch rotor. I was really looking to get some Brembo becuse of the connection I have there but they just tell me let us know what you need... but have no idea what to use on a Maverick. I know Tom H told me to make an adapter plate on the stock spindel but just wanna make sure I get the right rotor and would be better if I didnt have to make an adapter plate. But if you get any part number that you know works i'd be intrested in getting it. But thanks for the info guys as well.
__________________
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Disc brake conversion Article? zoojon Technical 9 2013-01-17 00:20
Help! Disc brake conversion question bigal3000 Technical 14 2004-08-04 11:53
Disc brake conversion - new parts bigal3000 Technical 15 2004-07-12 12:42
Disc Brake Conversion wardf Technical 13 2003-03-31 22:11
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
