2000 Cobra 4.6 DOHC
Discussion in 'Technical' started by L50watts, Apr 17, 2005.
  1. L50watts
    L50watts Member
    Winchester, Virginia
    72 Maverick Grabber
    Does anyone know if it is possible to fit a 4.6 DOHC engine into the compartment of a 72 Maverick Grabber?
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Sure it is possible, but definitely not an easy task. Shock towers would have to go.
  3. L50watts
    L50watts Member
    72 Maverick Grabber
    4.6 DOHC Install
    Was considering RC Motorsports complete mustang 2 system. This eliminates shock towers?
    Any other suggestions appreciated!
  4. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    The 4.6 is wider across the top than a 460. If I were to put either in a Maverick, I would convert to a Mustang II suspension. Then, you could put whatever you wanted in there...except a Chevy.:eek:
  5. mavman
    mavman Member
    Arkansas
    That would be a cool swap. Should fit with the M2 front suspension, though get ready for lots of work. It ain't exactly a walk in the park, but in the end...well worth it!
  6. L50watts
    L50watts Member
    72 Maverick Grabber
    2000 Cobra 4v
    Probably going to do it! Ford Racing has a great deal on this motor w/ trans. Complete set up. I believe for around $5500. Will be posting pics and progress. Will know in about 2 more weeks if I'm going to try this set up.
  7. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    I saw that setup in a 65-66 mustang yesterday at Fun Ford Weekend. He had done the MII suspension conversion and had made new flat, flush, very clean, fender aprons. That engine slap-dabbed filled the engine bay.
  8. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    I was thinking about doing the same thing, but Im putting a 5.4 in mine if i do it.
    I think I got a donor truck if my fiance's grandfather decides to quite using it as farm truck :)
    Just need a mustang II front end now
    Would be neat to see some pictures
  9. Rando76
    Rando76 Member
    Claremore, OK
    The 4.6 and 5.4 OHC modular motors are WIDE. I have one in my Thunderbird. (y) Post pics if you do the swap!!
