Bad head gasket. 250 What to do?
Discussion in 'Technical' started by Russ, May 12, 2005.
  1. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    Drove home tonight in the 73 4 door, with a boiling rad. and coolant seeping out between the head and the block above the spark plugs. I'm guessing head gasket. I have little knowlage of the 250 6. So I have a few questions::huh:
    1 What would be involved in changing the head gasket? What has to be removed ?
    2 Would I have to machine the mateing surfaces?
    3 I know newer cars with aluminum heads that the heads warp. is that the same wiith the old cast iron heads?
    3 Can I Re-use head bolts?
    4 Costs for parts?
    Thanks
  2. comet 75
    comet 75 comet 75 swap 302
    Quebec
    mercury comet 1975 302
    first thing to do is to lift the head to see if any damage to the block or head if crack apear and if not replace the gasket but it's sure a good thing to make veryfied the head it's not luxury.
    for the rest I let someone else answer
    good luck
  3. Jamie Miles
    Alto, GA
    I've had a few
    I hope you mean below the spark plugs? :hmmm:
  4. Craig Selvey
    Very easy to do. I have done it several times. I would recommend getting the head redone while it is off and put in the hardened seats. I would reuse the bolts...but that is just me.
  5. 71gold
    my "head" man told me...the 6 cyl. doesn't have enough comp. to worry about "hardened seats"...if the seats are not beat by now ...they want...JMO ...frank...:bouncy:
  6. Mavaholic
    When the controversy first started about harden seats, everything I read said the only time you will see any adverse effects is when you continually run at highway speeds all day long. Around town would have no effect. So unless you have and want to spend the money to totally redo the head, I wouldnt worry about it.
  7. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    I think I started something with replace mind the 3 third time. Is this contagious? Have someone help you lift that head up its heavey, you could hurt yourself.
  8. tim keck
    sharps chapel,Tn
    They say if you put on an '80-up head you can get a little more compression/HP out of it,plus it's already setup for unleaded.
  9. YellowStangDuan
    YellowStangDuan Member
    Arlington, Texas
    71 Grabber
    The late model head (78 and up?) also has bigger intake valves...
