Manual Steering Gearbox kits?
Discussion in 'Technical' started by Rando76, May 24, 2005.
  1. Rando76
    Rando76 Member
    Claremore, OK
    I'm having a hard time finding seals and/or a full rebuild kit for a manual steering gearbox. I'm converting from PS to manual and found that my manual box leaks at both seals. Napa can only get the lower seal. I know I could probably go to a seal supply and get the upper, but I wondered if anyone has run into the same issue. :huh:
  2. Mavaholic
    I took mine to a local place that rebuilds them. Even if you want to rebuild it yourself, they can probably get you the parts. Check your local yellow pages.
  3. Rando76
    Rando76 Member
    Claremore, OK
    Was it cheaper than buying one already rebuilt?
  4. Mavaholic
    I dont remember and I cant find my receipt, but I'm thinking it was around $125.
  5. 357 Grabber
    357 Grabber Maverick DieHard
    kentucky
    2 71 grabbers,72 Maverick , son has a 73 maverick
    if all else fails , get the lower seal...the upper wont leak THAT much..and you can always fill er up if it gets low..it would probably be a slow process
  6. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    If you are going from PS to manual keep your PS box. It just has a better ratio.
  7. Rando76
    Rando76 Member
    Claremore, OK
    I figured with a V8 and 15 inch tires it might be fairly stiff with an auto box... but not sure, because I haven't tried yet. :huh:
