gas tank swap done
Discussion in 'Cosmetic' started by fan2488, Sep 6, 2005.
  1. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    swapped the 70 tank for a 65-68 mustang tank. total time was about 8 hours.i think it was time well spent. i had to raise it 2" from original spot(hung too low).i do have some more pictures if you want to see them.here is the before and after.
  2. Mavaholic
    I'd like to see them. Looks great.
  3. MiteeMaverick
    MiteeMaverick Senior Member
    Jonesboro, AR
    1987 Mustang GT Convertible
    Re:pictures
    I would like to see more pics also and demensions of the tank.
  4. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Fan2488 did you have to vent the tank? The mustang tank does not have a vapor line so what did you do with the old vapor line? I'm trying the same thing but my tank sits under the car & some one took my vapor container off. So there is a vapor line that's just there.
  5. Mavaholic
  6. fan2488
    fan2488 Member
    spring,TX
    the car is a 69.5 so no vent line.i just used a vented cap. i also did this swap on my 73 also used a vented cap on it.i will post pictures as soon as i resize them.
    first picture is original tank removed.then hole enlarged.next is new tank trial fit.then tank at original mount hangs to low. then tank has been raised two inches.
  7. fan2488
    fan2488 Member
    spring,TX
    back view after raised 2". old and new tank. sorry for the bad descriptions about the pictures.
  8. Charlie
    Charlie maverick.to/grabber
    Indianapolis, IN
    1970 Ford Maverick Grabber (Modified)
    Did you compare any other tanks? 67-70? Or are they all the same pretyt much as the 65-66?
  9. fan2488
    fan2488 Member
    spring,TX
    65-68 are the same 69 and 70 are different.not sure how they would fit
  10. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Okay let me make sure I got this right. I can use a mustang tank with a mustang vented gas cap, then I do not have to worry about that vapor line not the container that is under the hood. My container is gone any way. I just found out someone took it off.
  11. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I noticed that
    64-68 tanks are 16 gal & 8 inches tall, this tank is widers by a few inches
    1969 tank is 20 gal with 9 inches tall, about the same with as 1970 tank
    1970 tank is 22 gal with 9 3/4 inches tall
    1971-73 tanks all go in from the underside
  12. fan2488
    fan2488 Member
    spring,TX
    i am using a vented gas cap so far so good.allthough you should get better gas mileage with the tube hooked up.i beleive the 1970 tanks also mounted from the underside. only the 69.5 were drop in. somebody correct me if i'm wrong.
  13. bmcdaniel
    You're wrong.
    :D
  14. bmcdaniel
    Looks good. I just wish I could afford to fill up a tank that big! :rolleyes:
  15. fan2488
    fan2488 Member
    spring,TX
    i stand corrected
