interior spray paint
Discussion in 'Cosmetic' started by Yellow72Mavrick, Sep 28, 2005.
  1. Yellow72Mavrick
    Yellow72Mavrick Banned
    Memphis, Tenn.
    1977 maverick 2 door ( my sons) 250 c4
    Anyone ever bought and used interior paint from Dearborn Classics, they have several colors including the correct color for my 72 as well as the prep spray. It sells for $9.95 a can and is supposed to be correct match. Any imput from the masses??? :confused:
  2. grbmaverickmo
    Aquashicola, PA
    I like the stuff called Sem, it has its own prep cleaner for plastic or vinyl and they have satin black which is real close to the factory sheen. I get it at my local Carqeust parts store. I hope this helps .
  3. FoMoDave
    FoMoDave Maverick Owner
    Cumming Ga.
    1973 Maverick 302 c-4,1971 Maverick 6cyl
    Does Dearborn Classics have a web site? Any ifo would help, Thanks.
  4. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Chris is right about SEM products,, great stuff. The real thing about spraying interior panels is the prep work prior to spraying ( like painting a car). I use lacquer thinner to wipe the panel prior to spraying. This does 2 things, it cleans the panel, and it heats the plastic up like a catalyst and opens what pores it has to accept and to retain product. I fought stuff like this in the past and an old timer turned me onto the lacquer thinner thing. Never had a problem since.
    Dan
  5. FoMoDave
    Cumming Ga.
    I have used SEM products before with great results but they do not always have the color or shade that I need .I have known about the laquer thinner trick for years.
  6. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    SEM is the absolute only way to go. On soft vinyl, you can use the vinyl prep and spray dye. For the hard pieces, you need to use the vinyl/plastic primer in between the prep and dye. I use 3M Adhesive, Wax, and Mark remover prior to applying the prep - After a thorough cleaning with soap and water.
  7. Wes
    Wes Maverick Police Dept.
    Western Pennsylvania
    '76 Maverick Stallion '76 Maverick Metro Police K-9
    If you have to use rattle cans, go with the SEM. I used product from a professional body shop supply that I shot with a touch up gun on my compressor. They made me perfect matches for both the metal paint and dye. If you have a compressor, this is the best way to go. The small touch up guns, even the cheap ones, lay down a much better layer of paint and dye with a much better end result. You can do well with rattle cans if you do thin layers and be patient. Make absolutely sure that you use vinyl prep on the vinyl parts after you throughly clean them and before you shoot the dye regardless of what kind you use.
  8. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    There is a professional auto paint supplier near me that sells SEM and can mix colors, to match OEM codes or your favorite color, using SEM dyes and paints. They can sell a quart can or whatever for your use.
  9. Yellow72Mavrick
    Memphis, Tenn.
    sounds like SEM is the way to go...I'll check my Carquest store on monday...ty guys...Jim
