rear spacing ???
Discussion in 'Technical' started by MaverickGrabber, Nov 13, 2005.
  1. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    ok got my new rims there 15x8 with 4 1/4bs put the rims on from the rear of the rim to the spring.....i have a little over 1 1/2 inchs .....problem is the outer lip of them is level with the inner finder lip....so thinking ill return them and get ....4 3/4bs????:hmmm:
  2. Scotty P
    Scotty P Member
    santa rosa, ca
    I run 4 7/8" on mine on a 8.5: rim. Fit fine with a small spacer with 275-60 DR
  3. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Dave,, your figuring should put your wheels spaced in the wheelhouse nicely. Factory backspacing on the wheels is 4.5" I believe.
    Dan
  4. MaverickGrabber
    Cardington, ohio
    thanks ..going to try and get the 275/50R15 Mickey Thompson ET Street Radial Tire the Tire Section Width:11.3'' not a lot more then the et streets i have on there now ofTire Section Width:10.5''
  5. Mavaholic
    I think 4 3/4 is too much. You will have to run spacers.
  6. MaverickGrabber
    Cardington, ohio
    if i use the 4 3/4 bs ill have just a little over 1"inch from the outer rim edge to the spring
  7. Dan Starnes
    West Central IL
    It is going to be very close on both sides with a tire that wide. I used to run a 10.5" tire on the back and had problems with both the qtr lip and the leaf spring. Cant remember what backspacing I had on the wheel though. I do remember I had to run a wheel spacer to get the tire away from the leaf spring.
  8. MaverickGrabber
    Cardington, ohio
    well going over the rims i checked the BS they was 4"inch they sent the wrong ones so i got a set of 4 1/2 bs on the way
  9. Mavaholic
    Its not the rims you have to worry about rubbing the springs, its the tires. Tires usually stick out past the rims. I put a set of 255r60x15 on 8" rims with 4 1/2" back spacing on my Stock 77 Mav. The tires just barely scrapped the springs.
  10. MaverickGrabber
    Cardington, ohio
    yeah but the rim has to fit right 1st :)
  11. Maverick Man
    California
    cant' wait to see the all 4 wheels on your car... but if you ask me 4-1/2 backspace (if thats what your talking about) is too much for that tire and the tire is gonna hit the leaf. from the way i read what you wrote if its hitting the fender lip and you go with more of a backspace the tire will hit the leaf like dennis said too (ok that makes two of us) :p . now with that presuming your rear end is stock. but live and learn ;)
    [maverickman says to himself - i run M/Ts and wheels should be 3-1/2 to 4 inch backspace on wheel! :yup: and roll the fender if need be! ]
    good luck ;)
  12. MaverickGrabber
    Cardington, ohio
    with 4 1/2bs i will have a little over 1"inch from the rim lip to the spring my MT et streets come out under 3/4"of a inch past the rim there on now there the 26x10.5 they have a Section Width of 10.5'' the ET Street Radial Tire has a Section Width 11.3''
  13. NICK DOMINICK
    Burke, Virginia
    4.5 should work just right.
  14. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    1971 maverick 2dr m2 front end coil over ladder bar rear suspension 472 ci. C-6 tranny
    I have 4.5 back space and 26 10.0 15 MT Drags.....mine dont Rub my leaf springs:huh: :D
