Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical > Parts Interchange
Notices
Reply
Thread Tools Display Modes
Old 2005-12-04, 17:01   #1
MikeG747
Member
MikeG747's Avatar
Vehicle(s): 1973 Maverick Grabber, 347 4V w/D-1SC, 1974 Maverick Grabber 302 4V, 1974 Maverick Grabber 302 2V, 1971 Maverick Grabber 302 4V.
Images: 46
Instrument Cluster?
Has anyone ever put an older Cluster in a 77. The 77 reads 100 MPH. Was wanting to put a 73 model in that is available that reads 120 MPH. I was wondering if the wiring is the same & if the Speedometer would read correctly etc.. My son's 77 needs a new cluster & we can't locate a 77 cluster.
Thanks, Mike
MikeG747 is offline   Reply With Quote
Sponsored Links
Old 2005-12-04, 17:09   #2
ratio411
Member
ratio411's Avatar
Vehicle(s): 1972 Sprint and 1975 Maverick
Images: 16
I don't know your answer, but if you do a search, I saw that topic being discussed in length. Was in the last week or two.
I like the looks of the earlier one myself.
I think 75 was the last year for it.
Good luck
Dave
ratio411 is offline   Reply With Quote
Old 2005-12-04, 17:25   #3
Mavaholic
Growing older but not up!
Mavaholic's Avatar
Vehicle(s): Original 72 Sprint Owner, 71 Comet GT, 69.5 Mav convertible project, 57 Ranchwagon
Images: 20
The speedometers are interchangeable.
__________________
My Comet GT Build
"Todays racing technology has diminished the role of the driver way too much. Back in the days of 4 speeds, the driver had a lot more to do with the outcome of the race, and I can't imagine anything being more fun than that." Ronnie Sox
Mavaholic is offline   Reply With Quote
Old 2005-12-04, 17:27   #4
Yellow72Mavrick
Banned
Yellow72Mavrick's Avatar
Vehicle(s): 1977 maverick 2 door ( my sons) 250 c4
Images: 2
Yep what Mavaholic said...
Yellow72Mavrick is offline   Reply With Quote
Old 2005-12-05, 20:33   #5
PART-TIME
Member
PART-TIME's Avatar
Vehicle(s): Grabber Clone
There is a difference with the early and late model printed curcuit sheet that mounts on the back of the cluster. I think there is an extra curcuit added for late model economy idiot light. If idiot lights dont matter, then everything should interchange. When changing from 100 MPH to 120 MPH, don't forget to get your speedo calibrated.
Ken
PART-TIME is offline   Reply With Quote
Old 2005-12-05, 20:46   #6
MikeG747
Member
MikeG747's Avatar
Images: 46
Quote:
Ken
Where do you go to get them calibrated?
Thanks, Mike
Old 2005-12-05, 20:51   #7
Mavaholic
Mavaholic's Avatar
Images: 20
Dosent need calibration. Its self contained.
__________________
My Comet GT Build
Old 2005-12-05, 22:08   #8
PART-TIME
Member
PART-TIME's Avatar
Quote:
Dennis,
You don't need to calibrate (change the plastic trans. gear)when you change the speedo from 100 MPH to 120 MPH????????
Ken
Old 2005-12-05, 22:29   #9
Jamie Miles
the road warrior
Jamie Miles's Avatar
Vehicle(s): 13 Mavericks
Images: 362
Don't know the exact years, but a cluster from a '71 Maverick would not plug into my '74 Maverick's wireing harness. The '74 plug was smaller then the 72's plug. You will probably have to take the clusters apart and and put the early guages in your '77 cluster. As far as the idiot lights, I "think" you should be able to swap the plastic film that clips into the back. Hard to explain without showing what I'm talking about...
As far as I've seen, '74 was the last year of the 120 mph speedometers.
__________________
facebook
1972 Maverick - daily driven 215,000+ miles since 2005. 433,000+ miles total on the car. Now with a 1980 200 I6/SROD 4 speed.. 2.79 rear gear, Rochester BC carb, single out header, MSD ignition, Taurus fan, 3G alternator. 31 mpg hwy. @ 70 mph / 25 city.
Jamie Miles is offline   Reply With Quote
Old 2005-12-06, 04:42   #10
Mavaholic
Mavaholic's Avatar
Images: 20
Nope. The difference is in the speedometer its self. They just have stiffer springs in the 120 movement. Its easy enough to verify. Just take a drill and hook it up to each one and run the drill full speed. It will read the same mph on both.
__________________
My Comet GT Build
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Instrument Cluster Regulator DAB Technical 4 2013-11-03 14:05
Wanted: 1977 Ford Maverick Instrument Cluster rusty New Members Forum 7 2006-10-12 13:39
Instrument cluster nawal's 70 Maverick/Comet Cars/Parts Wanted 2 2005-12-20 18:07
instrument cluster ironhead58 Maverick/Comet Cars/Parts Wanted 3 2004-10-03 11:34
Instrument Cluster MavJoe Technical 11 2004-06-23 12:32
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
