Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical > Parts Interchange
Notices
Reply
Thread Tools Display Modes
Old 2005-12-07, 00:55   #1
derkzander
Member
Vehicle(s): 1976 maverick 2door
Mavrick/fox body mustang suspension
hey guys
i was woundering if anyone has run fox body front and rear suspension. their is a lot of aftermarket parts like coilovers and camber plates and such. You could also get rid of the leafs in the back. do you think this is possible?
derkzander is offline   Reply With Quote
Sponsored Links
Old 2005-12-07, 04:37   #2
Mavaholic
Growing older but not up!
Mavaholic's Avatar
Vehicle(s): Original 72 Sprint Owner, 71 Comet GT, 69.5 Mav convertible project, 57 Ranchwagon
Images: 20
Anything is possible but it would take some major fabrication to get it in there, especially the 4 link rear.
__________________
My Comet GT Build
"Todays racing technology has diminished the role of the driver way too much. Back in the days of 4 speeds, the driver had a lot more to do with the outcome of the race, and I can't imagine anything being more fun than that." Ronnie Sox
Mavaholic is offline   Reply With Quote
Old 2005-12-07, 10:28   #3
streetrod77
Member
Vehicle(s): 77 comet
Images: 6
Air Ride Tech has a rear mustang air ride system that is a link suspension. I'm thinking with some minor fab work, it can replace the leafs. I asked them about it & someone did order one for a Falcon.
streetrod77 is offline   Reply With Quote
Old 2005-12-07, 11:04   #4
derkzander
Member
Thank you guys. Do you know of anyone who has done any mods like adjustible coilovers in the front.
Old 2005-12-07, 13:14   #5
streetrod77
Member
Images: 6
I can't say that I know of anyone but I'm sure its been done. There is a company that make them for the early stangs but it fits our cars too. I can't think of the company though.
Old 2005-12-07, 15:01   #6
Corbin Johnson
Senior Member
Corbin Johnson's Avatar
Vehicle(s): 73 LDO, 72 Sprint, 72 Sprint, 70 Grabber. NORCAL MCCI STATE REP.
Images: 6
Quote:
Try RRS: http://www.rrs-online.com/html/products.htm
__________________
70 Grabber - 351W/C4. Grabber Green, Black Stripes, Green/White Houndstooth Top.
72 Sprint - Factory 302/C4, PS.
72 Sprint - Factory 302/C4, PS, AC
73 LDO - Factory 302/C4, AC, PS. Converted to small bumper, grabber look-a-like. Tan LDO Bucket interior, British Racing Green.
Corbin Johnson is offline   Reply With Quote
Old 2005-12-09, 06:50   #7
ATOMonkey
Adam
ATOMonkey's Avatar
Vehicle(s): '69 & 1/2 Maverick
Images: 4
You would still have to put in a spring perch. I'd just go with the mustang 2 or pinto front end. The fox suspension is fundamentally flawed. The instant center and anti-dive geometry are all screwed up. The only way to make it handle at all is to use huge tires and super stiff springs so the junk suspension doesn't move and you've turned it into a big go-kart. An aftermarket Pinto/M2 front can be made with the correct anti-dive angles and the proper length and mounting points for your car. The rear end is even worse. The uneven, unparallel bars have a nasty habit of binding up when the body rolls a lot. So if you really stuff it into a corner it will push push push push LOOSE! Not a good thing.
Currie will make a rear end housing with whatever length tubes and brackets you want. I think a 4 link with a watt's linkage on a 9 bolt would be killer. Or you could do two lower control arms and one torque arm like a third gen f body or the ranger/aerostar. Of course, now you're talking about welding in a whole new frame in the rear. Spring perches, shock points, mounting points for the control arms. Might as well mini-tub it while you're under there.
There is no magic bolt up like the fox and the early cobra IRS share.
ATOMonkey is offline   Reply With Quote
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Mustang II Front Suspension mark460 General Maverick/Comet 13 2006-02-17 18:16
Mustang II Front Suspension mark460 Drag Racing 2 2006-02-06 13:10
70 mav roller w/ mustang 2 suspension cheap? pics inside jeremy Maverick/Comet Cars/Parts For Sale 17 2005-07-29 00:57
?'s on mustang II suspension swap mavgrabber01 Technical 2 2005-02-14 20:55
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
