Pukeing gas back out
Discussion in 'Technical' started by Jamie Miles, Jan 24, 2006.
  1. Jamie Miles
    Alto, GA
    I've had a few
    When I put gas in my car, sometimes it starts comeing back out. It's like it's overflowing or something, but I know that isn't the case. You have to really keep an eye on it and go slow for it to not do this. Anyone else have this problem? Sucks standing there waiting forever just to put 10 or 15 bucks worth of gas in. I've noticed with older pumps, I don't seem to have this problem. Just seems to be with the newer ones. :confused:
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    You have a clogged vent
  3. Jamie Miles
    Alto, GA
    I've had a few
    The vent hose isn't even connected because the steel line that goes to the front of the car is rusted out/crushed. Unless your talking about the actual plastic piece on top of the tank that the hose connects to.
  4. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    The plastic piece on top of the tank is a check valve,it could be bad.As for the gas pumps....I,ve noticed there is more air dispensed with the newer pumps.....I'd almost bet that you(we) are not getting the full gallon of gas for what we pay......
  5. stmanser
    Davenport, Iowa
    either the gas isnt getting into the tank due to a blockage in the filler tube... maybe about half way down... i would take it off and check.. dont just shove it into the tank..
    or
    the vent for allowing air to escape is clogged.. there needs to be a way for air in the tank to escape.. otherwise, with all the gas going in... it just pressurizes and then the air comes out.. the filler tube and dumps gas out in front of the air coming out...
    in either case, get it fixed..
    good luck
  6. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    maybe your car just doesn't like regular :D
  7. igo1090
    igo1090 Member
    catonsville, md
    many of the newer nozzles are more sensitive, also. i find the kick off varies from station to station and even just pump to pump in the same station. one station i use has one pump i just cant use. it kicks off almost as soon as i start the nozzle.
  8. Jamie Miles
    Alto, GA
    I've had a few
    Same here!
    Nothing is blocked, especially not the filler neck. I built this car less then a month ago, and everything was clean/in good working condtion then. This has the same gas tank and filler neck that was in my '74 Grabber and it did the same thing then to. I was just talking to my dad and he says all 4 Comet's he had did the same thing. I don't see how the vent not working could cause it, because the filler neck is about 3 times bigger then the nozzel on the gas pump, meaning it should be able to easily let the air out without forcing the gas back out. And even if that was the problem, I would think even with a perfect working vent that the gas pump could dispense gas alot more quickly then that tiny vent could let out the displaced air. But now I'm just thinking outloud.
    I'm going to go pull the filler neck out and look at it. There has to be something in there that is restricting the flow of gas down the filler neck.
  9. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    Both of my Mavericks do the same thing unless you pump it slow, has something to do with the design of the filler neck.
  10. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    new pumps have their kick of based off pressure, and i think the design on mav gas tanks may create alot of pressure during fill ups.
  11. j miller
    Polson, Mt
    my 4 door does the same thing ?????
  12. 71gold
    jamie,
    does your filler pipe have the breather tube in it? one of my cars didn't so i got a filler pipe that did...frank...:bouncy:
  13. waynes fords
    waynes fords Member
    fayetteville,Georgia
    1973 grabber,2004 ford dually,2000 gulfstream motorhome,2003 ford expedition,66 mustang gt
    Jamie most of the older cars did the same thing, its a problem with venting, older cars did not have very good venting while filling up and the air in the tank was not displaced as fast as the gas going in so it either clicks off the pump or goes slow into the tank or it sloshes back and takes along time to fill. my 64 ford did the same thing when I was in high school, good luck and glad you got one running again!!
  14. Jamie Miles
    Alto, GA
    I've had a few
    No, it dosen't have the vent tube. When I bought the car, it had a Granada filler neck and it did have the tube. That filler neck didn't fit correctly so I swapped the Maverick part over from my '74.
    Ohh well, I guess it's just one of those things you gotta deal with when driving an old car...
  15. 71gold
    i have another filler pipe. i will check and see if it has the vent tube.(y)
    ...frank...:bouncy:
