Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Miscellaneous Forums > Other Automotive Tech & Talk > Tool & Shop Talk
Notices
Reply
Thread Tools Display Modes
Old 2006-02-07, 10:29   #1
ATOMonkey
Adam
ATOMonkey's Avatar
Vehicle(s): '69 & 1/2 Maverick
Images: 4
Chain Hoist
I just bought a chain hoist for my garage last week. It's somewhere in the southwest right now on it's way up. I got it from CVF supply and it was pretty cheap, so I'm sure the quality isn't there. When I get it set up I'll let you guys know if it's an absolute piece of garbage or not. It was about $60 for a 2 ton hoist including shipping. I can spend more than that drinking on a Friday night, so I figured I'd give it a whirl. For as much as I'll use it (not much) I won't mind if it falls apart after a couple of years. Especially for the price. I would have just got a cherry picker, but I'm very very very limited on my garage space and it's way too cold and my neighbors complain way to much to work with the door open.
ATOMonkey is offline   Reply With Quote
Sponsored Links
Old 2006-02-07, 11:56   #2
elliot
Member
elliot's Avatar
Vehicle(s): 76 4 door 347 C4 & GV
I have a cheap 1 ton chain hoist that I got for 10 bux . Itst hanging from a small pice of chain thats wraped around two 6x2s that are bolted to the 4x4 studs using 4 half inch bolts. I`ve used that to pull many motors and I even used it to pick up a granada that had no spindles or axles so I could back a trailor under it . My 1 ton is still working fine so you`r 2 ton should last a long time .
__________________
No PB, no AC , no PS , no BS !
"I live in my own mind , an`t nothing but a good time , no rain just the sunshine out here in my own mind"
elliot is offline   Reply With Quote
Old 2006-02-07, 13:36   #3
ford84stepside
Lone Wolf
ford84stepside's Avatar
Vehicle(s): 1947 Lincoln Club Coupe
Images: 26
I only paid $149 for my cherry picker- the legs fold up for storage. I think they have gone up a bit now, though.
ford84stepside is offline   Reply With Quote
Old 2006-02-07, 14:24   #4
ATOMonkey
Adam
ATOMonkey's Avatar
Images: 4
Yeah, storage wasn't the problem, it was going to be the usage. my ceiling isn't tall enough, so I would had to do it with the front half of the car hanging out of the garage and the driveway has a slope to it. Even if my ceiling was tall enough there's not enough room to maneuver a cherry picker. It's barely a 2 car garage. Not much fun. When I get my super duper garage built with the 12 foot ceilings it won't be a problem.
Old 2006-02-07, 18:32   #5
Mavaholic
Growing older but not up!
Mavaholic's Avatar
Vehicle(s): Original 72 Sprint Owner, 71 Comet GT, 69.5 Mav convertible project, 57 Ranchwagon
Images: 20
I personally dont like cherry pickers because of the height limitations. I've used both but only owned a chain fall. For those of us that usually work alone, one thing nice about a chain fall is you can drop the chain down to the floor and lay under the car and shift the motor around while you raise or lower it. Try doing that with a cherry picker by yourself.
__________________
"Todays racing technology has diminished the role of the driver way too much. Back in the days of 4 speeds, the driver had a lot more to do with the outcome of the race, and I can't imagine anything being more fun than that." Ronnie Sox
Mavaholic is offline   Reply With Quote
Old 2006-02-08, 07:13   #6
ATOMonkey
Adam
ATOMonkey's Avatar
Images: 4
Well, it's somewhere between Phoenix and Indianapolis right now on a Fed Ex truck. I should probably start shoring up the roof and figure out where the best place would be to put this guy. I'm probably going to have to spin the car around too. hhhmmm.... not much fun with no way to power it. I'm glad these cars are so light.
Old 2006-02-10, 17:04   #7
ATOMonkey
Adam
ATOMonkey's Avatar
Images: 4
Well, i got the hoist today. Not too bad. It's definitely beefy! The actuation is a little clunky, but it's definitely going to get the job done. It looks like a reman which might explain the low price. Oh well.... I'm happy.
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Timeing Chain Setting??? halies72 Technical 22 2007-01-10 20:11
How much slack is too much slack in cam chain scooper77515 Technical 8 2005-04-12 18:41
1976 timing chain cover tony4eight Maverick/Comet Cars/Parts Wanted 4 2005-04-03 10:38
loose timing chain cause of knock? 71351wmav General Maverick/Comet 4 2005-02-11 18:15
Powered by: vBulletin
