About headers and trans.
Discussion in 'Technical' started by Masta T, Feb 27, 2006.
  1. Masta T
    Masta T 1337 |\/|4\/3R1(K
    Florida
    1973 Maverick 302
    I just got some 6901 hooker headers, and i figued installing them shouldn't be too bad, boy.... was i wrong.
    the right side went in great,then it was on to the left side. I saw that I had to raise the engine up and few inches, and that was no biggy.
    I tried squeezing them up there, and I was fighting them badly, so I removed parts of the shifting bars, that go to the trannie, and tring to jam the headers up there, they were hitting on the parts left over, and when I got the heads up into the area, the shifter peices were bent a little and trapped under. And they been driving me crazy, cause there not fittng in there that well.
    and about the transmission, they said they will not fit a C6, and I figed that it was a C4 or C5, maybe I was wrong, and thats not why their fitting.
    my car is a 73 302 with automatic.
    maybe i should just go hook up a floor shifter instead of a worring about the colum.
    you guys got any suggestions?
  2. don graham
    6901 headers won't fit on a column shifter without modifications. may be something in the archives about it. a couple of members have done them. hooker says in there catalog that they are not for column shifters. i have a floor shift and they went in pretty easy.:)
  3. benben
    benben Member
    Europe, Estonia, Tallinn
    Mav`75, 302, 2d, A/T, A/C
    I like column shift and I throw away that multiangle linkage between two rods, upper and lower, then weld together upper and lower rods, bent them to a right angle and thats it. Attencion when you weld this rods together, the ends of the rods shud be in the right direction, they shud fit with the bushings.
  4. Masta T
    Florida
    1973 Maverick 302
    I could try that, do you have a pic or something I could see.
    That would be better than having to buy a floor shifter for $150.
  5. benben
    benben Member
    It may takes day or two, to take picture and send...
  6. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    I'll be going this route in may, so I'm watching for those pics too!
  7. Masta T
    Florida
    1973 Maverick 302
    yea ben, a lot of ppl would enjoy those pics.
  8. benben
    benben Member
    Tomorrow :yup:
  9. benben
    benben Member
    here is the pictures:
  10. Masta T
    Florida
    1973 Maverick 302
    awesome.
    thanks for the pics Ben.
  11. Masta T
    Florida
    1973 Maverick 302
    :bananaman I got the pieces welded and bent just right, and the shifter moves good.
    but on the gauge bar above the steerring, it is a bit off.
    when its at first gear it shows it at second, but besides that work great.
    ill posts some pics of the bar by its self and stuff. so others can see.
    This pic shows the bar before its ready to go back in
  12. NICK DOMINICK
    Burke, Virginia
    I had trouble with my same headers with a floor shifter. I had to heat up and bend the linkage that goes from the transmission to the collar on the steering column.
  13. xpsnake
    xpsnake Bruce
    Thanks again for all the info guys, this'll help me with my 6901's and column shift.
  14. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Hey it's a jungle weld, I see apples and oranges:D
  15. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
