Project Trunk Separator Finished ...
Discussion in 'Technical' started by dmhines, Mar 3, 2006.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    My trunk separator was looking bad. Had some tears and yuck on it. I did cover it with splatter paint when I did the trunk but it still wasn't worthy.
    Here is what I did to make a new one.
    1) Get 30# Roofing Asphalt Paper
    2) Remove original separator
    3) Use original and trace onto new paper
    4) Cut it out
    5) Hang new one in car
    6) Hang original one over new one for reinforcement since the original is much thicker.
    7) Sit back and admire
    What is interesting is the the new roofing paper had shingle guide lines drawn on it. I never noticed but the factory separator has the same guide lines drawn on it ... maybe it truly was roofing paper from the factory!
    Here are some pictures ....
    http://web.mac.com/dmhines/iWeb/Our Website/Grabber Trunk.html
    I am also installing my two piece carpet ... that's another thread ...
  2. Maverick Man
    California
    ncie job.. when you comming over to do mine?:p
  3. dmhines
    Cumming, GA
    You're on the wrong coast! Actually .. I was gonna trace and cut a second one out to use as a template since most peoples are not suitable to trace or are completely gone ... however, I didn't have enough Material to make a second one ... :(
  4. 71gold
    trace it out on paper and copy it..500 times...then you could send a template to all your friends (like me) (y) ...frank...:bouncy:
  5. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Dan,I'd like one too.....
  6. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    looks really good dan
  7. dmhines
    Cumming, GA
    Now look what you did Frank!
    I'll see if I can get some sort of material that I can make a durable template from before I put the rear seat back in .... some heavy vinyl would be the best. Then I could roll it up and ship it to folks in a tube if they want to borrow the template.
    The one in my yellow car has a large tear in it so I'll be putting one in there was well ... eventually ...
  8. Craig Selvey
    Dan
    For my sub speaker template I used just regular paper with all the cut edges taped and protected with shipping tape. I have mailed this out and got it back several times and it is holding up wonderfully. I can fold it up and stick it into a standard 8 x 10 envelope.
  9. Jamie Miles
    Alto, GA
    I've had a few
    Looks good Dan!
  10. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    From my days as a carpenter, I'd say they probably did use roofing paper, the nail lines look the same. Maybe Ford had a special contract for a thicker material.
    Anywho, LOOKING GOOD!!!
  11. 71gold
    dan,
    send me a copy with wayne tomorrow...thanks...frank...:bouncy:
  12. daydreamer
    daydreamer Mavmenace
    Oshawa, Ontario
    1972 Ford Maverick
    I have the heavier paper in my mav.. its torn in a few locations and I have been trying to find a replacement piece.. no luck but have found out the thick stuff is known as 90# paper. used on OLD houses were they used random boards of different widths.. not available up here anymore.. .. there is some stuff called leakpreventor.. it has a sticky side and when you put 2 pieces together you end up with 1 piecethat is real close to the original thick ness.. thats what I plan on doin .. hope it works:huh:
  13. Earl Branham
    Lugoff, SC
    Dan; need to talk to you about the two-piece carpet. Looks great. Catch you later,
    Earl
  14. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Dan, I can't believe that you openely admitted you were actually driving your
    Maverick around with that horrific tear in the roofing paper in the trunk! :eek:
    Ha! Man, I wish that was all I had to do to my Maverick to get it back to factory
    original! Nice job (as usual). I appreciate and admire your attention to detail.
    (Ctrl^D)
  15. Islandmav
    Islandmav Member
    Whidbey Island, Washington
    '70 Maverick, '73 Grabber
    Dan, it looks great! I also wondered abut the lines on the factory paper. It sure seems like good 'ol tar paper to me. My only comment is that roofing felt is very flammable and if someone isn't going for a factory look, it sure would be nice to get a panel of a different material in there... I don't have an idea what, but thought I'd throw the issue out for others to consider.
